Question about Haier HBCN05FVS Wine Cooler
Whining noise
Refrigerator stays cold but high pitch sound how do i fix it
What is the whining noise when I start my Corolla T Sport from cold?
bettr get a new timing chain-will break soon and hurt motors valves--put a new water pump and engine seal at same time-save$--hav an xperiencd independent du the job--dealers are usually troubl
May 28, 2014 | 2009 Toyota Corolla
Whining noise on 2002 chevy tracker, comes and goes
Could be your alternator or a bad idler pulley. Is the transmission good? It may be the tranny or your differential whining.
Feb 18, 2013 | 2002 Chevrolet Tracker
Fan in top of the refrigerator is making a high pitched whine when running
The high pitched noise is likely a bearing on the fan motor going out. You should replace the motor soon as it may fail completely.
Oct 18, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
Magic Chef refrigerator makes high-pitched whining
well u need to get it check by any expert throughly u need physical assistance u have done much.
Jul 25, 2009 | Magic Chef CTB1821AR Top Freezer...
High pitch whine
sounds like your one of your hubs on the front axle are staying engaged when you turn off the 4wd. By reselecting the 4wd high and back to 2wd hi it is causing it to release. Get it looked at these can get expensive if damage is done.
Jun 18, 2009 | 2004 Chevrolet S-10
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High pitched sound from fan
were is the fan making the noise if it in the freezer and making noise check for frost eany frost you may have defrost problem if it is in the refrigerator change fan if is the condenser fan change
Apr 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hss25gfpdww The unit makes a horriable high pitch whining noise a
I am not posotive, but it sounds like you may have a piece of debris stuck in the fan underneath. You can check if you pull it out from the wall, make sure you unplug it as to not have the fan come on while you are toying. But thats what it sounds like. If that is not it, I am sure you could locate the noise with it pulled out from the wall, and go from there, Possibly your compressor, but sounds like the fan the way you're explaining it. Good luck
Feb 14, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whining noise from freezer
Fan motor is bad and needs to be replaced.
Nov 26, 2008 | Refrigerators
Haier HBCN05FVS Wine Cooler Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
