Question about Salton JM411 Juiceman II Elite Juicer
Unable to take juiceman apart to clean
How do I take apart juiceman to clean?
  • 3 more comments
  • mgbkhali Feb 09, 2009
    i cant get the top off to clean out basket
  • Anonymous Mar 11, 2009
    I can't take the top off to clean our start using te juicer...help
  • kharris11 Mar 11, 2009
    I can't take the clear lid off the basket part to open & clean...I got the juicer with no instructions...help! Thanks
  • Anonymous Apr 26, 2009
    thank you for the solution, i have spent the last half hour trying to get the basket out .
  • Anonymous Mar 30, 2014
    blade is stock
  • 6 Answers
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Tom
Posted on Mar 08, 2009
  • 3 Answers
Soaking in hot water did not work for me. Here is the solution I discovered.
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
Posted on Feb 15, 2010
I used a screw driver under the lip of the stuck filter bowl. Pried up gently around the edge. It popped off! After storing for over a year.
Posted on Jul 12, 2011
2 Suggested Answers
SOURCE: HOW DO I GET MY JUICER APART TO CLEAN IT
I looked all over for the disassembly instructions for the JM300 to no avail...so I got a flathead screwdriver and decided I'd either get the darned blade out or break it for good. It took some prying but the blade popped out and it was the RIGHT way to handle it after all. Now everything is clean and ready to use again.
Posted on Sep 24, 2009
How do I disassemble a Juiceman ll?
Search Results
    How to Use the Juiceman II Juicer Instructions - YouTube
    ? 12:57
    www.youtube.com/watch?v=sQgtIojaeVk
    Feb 1, 2012 - Uploaded by DiscountJuicers.com John from http://www.discountjuicers.com/ explains how todisassemble, assemble and juice with the Salton
Sep 22, 2015 | Juiceman Juicers
Manual for juiceman 2
Keep in mind that this item has been discontinued; however, you can find some details in this links:
- Juiceman II Elite - User Guide
- Juiceman II Elite J411 - User Guide
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice weekend.
Nov 18, 2011 | Juicers
Need a juiceman 11 juicer instruction manual.
I have a manual for the 211, let me know if you're interested and I can scan it.
Sep 17, 2011 | Salton JM411 Juiceman II Elite Juicer
I have a Juiceman professional series 211 a ns lost the directions for use. Can I download them from somewhere
Hello. I recently inherited a Juiceman Pro Series 211, and I needed a manual for it. I want to take the best advantage of this fine system.
I contacted Juiceman Customer Service, 800-738-0245, and asked them for help. They sent me to this website http://useandcaremanuals.com/ so that I could download the JM Pro 211 manual.
From what it looks like, there are many other manual there for other appliances, too. Hope this helps.
Feb 06, 2010 | Juicers
Looking for a manual for juiceman 210
Here you go:
http://common.csnstores.com/common/marketing/jcm1003_user_manual.pdf
Jan 02, 2010 | Juicers
Sep 14, 2009 | Juicers
Cannot remove juice bowl from Juiceman 410. Yesterday it was ok.
TRY INVERTING IT AND SOAKING IN A
SOLUTION OF OXI CLEAN AND HOT WATER.
Jun 28, 2009 | Juicers
Salton JM411 Juiceman II Elite Juicer Logo
5,074 people viewed this question
Top Salton Juicers Experts
Simon Flummox
Simon Flummox
Are you a Salton Juicer Expert? Answer questions, earn points and help others
