Perfect settings for lg 42cs460 42 ins full hd lcd tv
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
stradeteox
  • 88 Answers
SOURCE: I have an LG 37LC2D LCD TV that is locked.
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) are the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
Posted on Jan 11, 2009
jan mczeal
  • 632 Answers
SOURCE: Bush TV LCD 32 TV 005 HD
The black screen problem of your TV can be attributed to a backlight driver failure, busted backlight, or LCD driver failure.
The flickering indicates a failing backlight driver or a failing backlight. The screen should be totally black, without any glow, when either of them is not working. To verify, grab a torch and shine it on the screen. You will be able to see a faint display telling you that the backlight is busted or the backlight driver is faulty. If not, the LCD driver or the LCD panel itself is faulty, although it has a low probability due to the symptoms of the problem. The only way to fix the problem is replacement of the faulty part. You may need the service of a qualified technician to determine exactly which one is the root of the problem that needs replacement.
Posted on Dec 07, 2009
  • 1121 Answers
SOURCE: LG LCD TV/DVD - I have full picture and sound with
is a mute function enable or a defective control board. Needs to be checked. send to repair store.
Posted on Jan 16, 2010
joeguest2
  • 2080 Answers
SOURCE: Have a 42" LG LCD
Sometimes this is an indication of a bad LCD Controller Board (or TCON board). Sometimes it's even just a loose or improper connection with one of the ribbon cables leading into it. When the set heats up the connection expands and makes better contact and functions somewhat better. If you remove the rear access panel you might be able to see the Tcon board. It will probably be under its own metal shield / cover plate. It will have a bunch of wires wrapped in a steel braided shielding cable leading into one side of it through a connector. It will also have 2 or 4 thin flat ribbon cables leading out the other side of it via plastic connectors going to the actual LCD panel. You can google it to see pictures of a Tcon board, it will look similar to the one at this link: http://cgi.ebay.com/LG-6870C-0080D-LCD-DRIVER-BOARD-MDL-42LC2D-UD-APUSLL-/170504013027?pt=LH_DefaultDomain_0&hash=item27b2d4c4e3 You can try flipping up the little plastic retainer clips that hold these flat ribbons in place and gently pulling the ribbons straight out. There will be some gold / copper contacts right on the tips of these ribbons. Sometimes they get oxidized and need to be gently cleaned with a pencil eraser to make them shiny again. Then just slide them straight back in the same connectors and flip down the little plactic retainer clip to hold them in place again. I am assuming of course that the unit is unplugged while you do all this and that the warranty has already expired. If you have any more questions or require additional assistance, please comment back on this page and I will endeavour to help you. Good luck, and if this was at all helpful, please click on the 4 Thumbs Up rating icon above. Thank you very much. Joe.
Posted on Feb 15, 2011
My lg tv screen is totally pink/red
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 08, 2015 | LG 37LF2510 LCD TV 37 inch (94 cm) 16/9,...
How can I connect my laptop to my LCD TV through HDMI cable (brand:LG) (model:LF15 series) HD ready?
You'll need to make sure that your laptop & LCD TV have an HDMI port. If they both do, simply connect an HDMI cable from your laptop to your LCD TV and make sure the input on the LCD TV is set to receive A/V from the HDMI port.
Jan 11, 2013 | LG Televison & Video
I have a Full HD LCD LG tv, it is printed on the tv itself that it supports 1080p, but when I plug my PS3 and change the settings to 1080p, the screen goes black for about 5 sec, and comes back for 2 sec,...
Rather than actually trying to set the display resolution up from within the XMB (which does cause come problems) try my guide to reset the display to its highest possible resolution. Make sure only your HDMI cable is plugged in when you do this -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Hope this fixes the problem for you
Jul 31, 2011 | Video Game Consoles & Games
I am trying to commect to my PS3 to an LG LCD tv which supports 1080P (Full HD). but as the game starts and when i check the TV it says 720P although the game and the TV both supports full HD. Do i need...
Hello there. There's a few possibilities. First, the obvious, do you have it set to 1080P in the Display Settings options? Secondly, are you using an HDMI cable? You need to be using HDMI to play games in full 1080P. I use the component cables (The red, green and blue ones) for my PS3 and when I'm on the XMB (that's the PS's desktop so to speak) it's displayed in 1080P but games will not play in 1080P, only 720P. Any old HDMI cable will do the trick, so don't get suckered by the price if you are going to pick up a cable!
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
I have on LG 55LH40 LCD TV problem 1 Have a
You need to set your aspect ratio, check your manual.
Apr 05, 2010 | LG 55LH40 55 in. LCD HDTV
My lg tv will not go into hd mode, i have a hdmi
upgrade software file needed from lg using usb port.
Feb 02, 2010 | LG 42 in. Flat Panel LCD HDTV
How do I get a full screen hd picture without the black space at the top and bottom
on my tv i went to the settings and it has an option for letter box,which thats what you would want to get rid of,check display,or tv settings
Oct 19, 2009 | LG 47LC7DF 47 in. LCD HDTV
PICTIRE SETTINGS
1. you should have a HD source, such as direct tv with HD channels
2. You need to connect this source with a HDMI cable
3. Make sure all the setting match from the source to the tv
May 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
LG 42 inch HD LCD (42LB9F)
Try what they suggested. The attenuator may block some signal that is causing the difficulty with your set. And it is installed on only the line going to your set and not the main line coming into the house.
Apr 30, 2017 | LG Televison & Video
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
Electro Med Services...
