Question about Power Acoustik PS2-1600 Car Audio Amplifier
Boston acustics gts 750 stayin on protect mode
2 Suggested Answers
  • 13 Answers
SOURCE: stayin on protect mode
before turning on disconnect speakers, power up the amp and check if it is still in protection
Posted on Apr 18, 2010
How do you fix a boston Horizon Duo - I as the unit just turns on and makes a load humming sound and then th edisplay switches off
If you are lucky, it only went in protection mode and after disconnecting the power for a little while and reconnecting things could come back. But if the system did not have an overload protection, a fuse can be blown, or worse the power supply or power amp can be blown to pieces. There is one thing semiconductors don't like is work over their limit.
Sep 12, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
How do i reset kicker kx 850.2 from protect mode ?
If it goes into protect and your speakers and wires are good, chances are you have bad output transistors that will need to be replaces.
May 12, 2014 | Zapco Reference 750 Car Audio Amplifier
My Boston Acustic subwoofer connected to my Denon Avr 1312 is not turning on the les light on back of subwoofer dobt even come on had fuse checked but its not blown.
There is a common problem with a zener diode in that amp that goes bad. ZD3 is a 18v zener and it goes short. Sometimes R9 on the back will open when this happens. Need to have them replaced.
Oct 09, 2013 | Denon AVR 1312
Blaupunkt boston c22 radio code, need code
Hello I need code for a Boston c22 Serial nimber : bp2750p7447219 and 7642750010 Tank you
Dec 24, 2012 | Car Audio & Video
Stayin on protect mode
Apr 17, 2010 | Power Acoustik PS2-1600 Car Audio...
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
MODEL QUESTION
I wasn't able to find a schematic diagram. Could you please send a picture or pictures from the top and bottom of your device. close ups of the circuitry from top and bottom will help to determine where that wire is connected to jah2mil@hotmail.com
Thank you.
Jul 07, 2008 | Audio Players & Recorders
Problem with boston acustics subwoffer
> check it in another computer
> if problems persist check setting of speaker also connectivity
Dec 02, 2007 | Boston Acoustics MicroMedia Computer...
Screen way too bright / you can see the lines
this hapens when you are in humid conditions..Thats why the best thing you can do is to use a protective vinyl casing..so that your phone is well guared from moisture..Also check if the brightness and contrast are too high..
Oct 22, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Prower acustic amp in protect mode
1) Make sure the amp is properly connected to +12V power source. 2) Make sure the amp is grounded well, directly to metal - if you have a voltmeter, an easy way to check the first two is to see if there are 12 volts across the power and ground wires. 3) Make sure the speaker output wires aren't touching each other. If none of these are the case, there is an internal problem with the amp and it should be serviced or replaced.
Sep 18, 2007 | Car Audio & Video
Power Acoustik PS2-1600 Car Audio Amplifier Logo
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
