Hello, i bought my Olympus FE-310 Camera Least year, but everytime i try to turn the camera on it says batteries are dead, so i bought new batteries and the promblem still continued with different brands of batteries. The Camera is not even a year old, and i've this problem over a month thinking it would fix its own problem. Now i have no camera that will work and seriously this is ridiculous! Any tips that might help?
-   sometimes i feel that my batteries is so wastefull and i also have problem on setting the camera...
and i can't catch a good picture at night with my olympus fe-310-   fenx_chonk
Mar 29, 2009
-   Whether its the battery sensor or something much more grave. This camera did not make it more than two months if that. I wish I could say this problem is that of few, but from all of the feedback I've read here and on other sites.. this is a very very common problem.-   Guest
Mar 13, 2009
-   just after remplacing panassonic battery (original with camera) all the the time lcd message "battery empty" even if with a new rechargeable sony battery NI-MH 2100mAH
its shame for olympus-   trensbigs
Mar 06, 2009
-   Exactly the same as being outlined below, turn on, two shots later, red flashing battery, followed by Battery empty message. Have tried numerous different batteries, including buying re-chargeable ones. I have barely taken thirty shots so the product appears to be a complete waste of money and time trying to resolve, it has put me off Olympus for life -shame as they used to be good.-   Guest
Feb 26, 2009
-   I contacted Olympus and was told this is a problem they discovered after manufacture. In essence a design problem. I sent the camera to Olympus under warranty and it came gack to me in the same condition. It appears as though the problem cannot be fixed. I am sending it back again with a request for a replacement with a different model. Will let you know what happens.-   75Beetle
I have the same model and I sort of took a page out of Solution #2.
I don't have electronic technician experience so I took one main insight: The Poor Design of the Conduction in the bottom cover.
Here's what I did: I took some Copper Wire (mine came from the wire you use to hang paintings) and some Aluminum Foil.
Next I wrapped the Copper Wire with the Foil. The piece was roughly slightly bigger than 1/2 of a Postage Stamp.
Then I inserted this metal square over the batteries and closed the cover.
I found that I could take more shots without the camera saying Battery Empty.
See if this works. So far it's touchy but it's been taking more photos than before.
I have had the same issue when using rechargeable batteries. I find that if I use Duracell Procell, or some other "high capacity" battery the problem is resolved.
I have an FE-310, and had nothing but problems with battery life also. I tried a number of different branded rechargables with no success. I'm currently using the SANYO Eneloop batteries. Being an electronics technician by trade, it got the better of me, so I worked out the problem. The problem is in the battery closing flap on the bottom, it has poor electrical conduction to the batteries, and the voltage from the 2 batteries in series drops from 2.9V to 1.7V on turnon as a result. The camera seems to use a lot of current on turnon and on some other functions like taking a photo. The fix is to disassemble the unit an install a small capacitor across the battery terminals. I used a surface mount 2.2 uF 10V capacitor, which just fit between the two batteries up against the front case. I can now get over 500 shots without getting the red battery symbol. It's a bit tricky, but most technicians should be able to do it.
Mine does the same all the time. I usually turn it off, take out the batteries.. put them back in and turn it on again.. it used to work that way but recently after my rechargeable batteries got stolen i started using regular ones.. now everytime i put in batteries rechargeable or not.. it doesnt even turn on..
i checked the manual of the camera and in the batteries section it recommends alkaline batteries and panasonic oxyride batteries
i searched up oxyride batteries and learned that they are double the power of regular alkaline rechargeable batteries..ive read customer reviews on them and everyone says that oxyride batteries are best for cameras like the FE 310 that die out quickly.. i know that best buy and future shop dont have them.. appearantly target and walgreens do.. i havent checked yet but if they work ill let you know...
in the meantime, search them up, see reviews and learn for yourself what theyre like
once again theyre the Panasonic Oxyride batteries
Was this helpful?
Yes
No
Popular Solutions for Olympus FE-310 Digital Camera
the lens stays out. sometimes when you press the on button the lens goes in then comes out again. ...
(More)
the lens stays out. sometimes when you press the on button the lens goes in then comes out again. the screen is not going on but is not cracked or damaged.
Whenever i turn on my camera its says "Clean Contact area of the card with a dry cloth" I...
(More)
Whenever i turn on my camera its says "Clean Contact area of the card with a dry cloth" I ve done that everything you could think of. It gives you to options Clean Card or Format. I have done both and neither had worked
I am having the same problem. When I bought this camera it worked fantastic, now its a real pain and I too have spent a small fortune on batteries. My mothers camera is about 6 years old and does a better job then this. I had high hopes with the name Olympus, but since have lots faith in this product.
I bought the camera in march of 2008 to take pictures in paris... it worked fine for a few months, but in the last two major trips i've taken, it keeps telling me the batteries are dead! i've spent a small fortune on new lithium batteries and it will take two pictures then freezes. i have to remove the batteries, put them back in just to close the lens! is it draining the batteries, or is the sensor that reads the batteries broken?
