Question about Technics SL-MC50 CD Player
TECHNICS SL-MC50 CD CHANGER
I AM HAVING ERROR EASH TIME I TRY TO PLAY A CD.IT WORKED FINE ONE DAY AND THE NEXT I ONLY GET ERROR.WHATS WRONG?
  • Anonymous Jan 31, 2009
    Same problem - I opened it up and there is a string that is disconnected from something.
5 Suggested Answers
SOURCE:
  • 112 Answers
SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
Posted on Feb 29, 2008
  • 6 Answers
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Posted on Mar 01, 2009
ginko
  • 19396 Answers
SOURCE: When Making A CD To Play On My technics SL-PD8 It
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
Posted on May 03, 2009
SOURCE: Looking for a drive belt
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Posted on May 21, 2009
For the(Technics Compact Disc Changer SL-MC59,60+1 CD Changer/quick change system)The equalizer is working,the control stereo Reciever is working but,the compact disc changer itself will not work. It...
if you can get to the laser eye take a paper towel or tissue paper soak in rubbing achole and clean the eye if you cant reach it or it is hidden in the mechinism get a disc cleaner and run that in the system it sounds like the laser eye is dirty i do it to my cd player all the time when it can't read the disc
Dec 21, 2012 | Audio Players & Recorders
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
I have not played my cd changer for a year and when I just try to play a cd now the system appears to look for cd but the word error comes up on the display. Just the word error not number. Any ideans...
Hi!
I dont't think that your cd-changer is broken. It may only need some cleaning. One year is time enough for dust to set on optical reader. I suggest to use a cleaning disk, available on every store selling optical media.
Hope it helped,
Bogdan
Sep 23, 2011 | Technics SL-MC70 60-Disc CD Changer
Hi i have a techniqka hi fi MC-208 when i put a cd in it plays for a bit then 0P shows on the wee window so i cnt play cd... How can i resolve this... Thanks Kerry
try to turn it off an on while holding the play button. try 2 go online an look for the meaning of your (op). type in .technics sl-mc-208 cd player 0P problem
Mar 15, 2011 | Technics SL-MC50 CD Player
SL PD887 5 disc CD changer was working one day but not the next day - does not read the CD - goes from one CD to the next but unable to read each CD in the changer. Have changed the CD's and cleaned the...
I have a model sl-pd847 and experience similar problems to many other submitters. I checked the main pcb and found discolouration around what appear to be 2 (power?) transistors and probably a voltage regulator. After about 4-5 minutes after switch on these get really hot. I suspect that may be the reason why it doesn't work anymore. Worth fixing? I don't think so. This one didn't even play CD-R let alone CD-RW! Get something a bit more up to date I say.
Jan 16, 2011 | Technics SL-PD887 5-Disc CD Changer
I AM HAVING ERROR EACH TIME I TRY TO PLAY A CD.
When your CD does not read any disk, and returns error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, or a faulty spindle motor unit.
If it is a lens problem, then you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , the unit will start losing the rest of functions, and ends up not reading anything at all, and returning error.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player , and clean lens directly with q tips and isopropyl alcohol, or to replace the lens, or the whole drive unit.
Sep 04, 2009 | Technics SL-MC50 CD Player
My Technics SL-DZ1200 will not play certain MP3 tracks. It will play some, but on others the message "track error" appears. these same disks will play just fine on the other cd player machines I have...
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Jun 08, 2009 | Technics SL-DZ1200 CD Player
May 02, 2009 | Technics SL-PD8 5-Disc CD Changer
String ???
Yes, I have a soloution to this "String" problem.
Only because I have repaired mine twice already.
Unscrew the unit and take cover off,you will see the mangled "sting" wich is actually more like aviation cable takes some skill and a pair of steady small hands to fix.
you have to re-thread the wire back into position by hand on the left hand side you will see small wheels where the cable sit's in then rethread the changer post with 4 wheels thred it inside left bottom to outside left top, to over right top to inside bottom right.
I have temporarily fixed it. if you shake or mis handle the unit somehow it will fall off again!!
The reason for this is when the disc's change the guide wire will get looser with age and fall off.
the proper way to fix this is to take a pair of pliers and pull the string out the side where it is fastened pull it tighter to reduce the slack in the cable DO NOT over tighten or it wont change discs at all!!
keep playing around with the cable till it's re-threaded properly, you'll know when it's threaded right and be carfull not to bump it back off while screwing the cover back on. It's almost like re-threading an old movie projector.and if you feel daring you can try my permanant fix suggestion to tighten it some how with pliers to reduce the slack.
I almost threw my CD changer out when that happened i thought it could'nt be fixed but it is possible and it works fine.
I have not permanantly fixed it myself with pliers, but i'm pretty sure it would work, that way you wont have to rethread it everytime it falls off.
Aug 29, 2007 | Technics SL-MC50 CD Player
Won't stop playing.
In the Carousel on the far left there is a slot marked single. Place your favourite CD in that slot and when it's bed time press the single button to the left of the Direct & Program buttons on the front of the unit. Then press play, only the CD in the single slot will be played. Enjoy. Always, Alvin T.
Nov 10, 2006 | Technics SL-MC50 CD Player
Technics SL-MC50 CD Player Logo
437 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
