Question about Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate P3001 Car Amplifier i think i crossed the speaker wires and now the amp burns the fuse
SOURCE: Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
Posted on Sep 02, 2007
  • 149 Answers
SOURCE: Rockford P3001 amp not working
peel the cover completely off the amp and give it some power- if the amp is blown there will be a tiny light lit up on the circiut board that quite simply says "SHORT"-If its blown then theres nothing you can do unless you are a badass of course- but if the amp is dear to you and you want to spend a little money on it to get it up and running again- go to rockfords website and get into the forums and ask the question-where do i get my fosgate fixed and it will pull up some mumbo jumbo but it tells you about a place called LANDIS TECHNICAL that bought up all the parts to their amps and is in the business of restoring the amplifiers to their factory specs and even sends you a new power certificate to go with your new and improved amp.hope that helps you-
Posted on May 27, 2009
SOURCE: ROCKFORD FOSGATE Punch 301M Amplifier Problems!!!!!!!!!
check the resistance inside the amp ihave one 2 and they actually burn fast....
Posted on Jul 08, 2009
bill_48632
  • 149 Answers
SOURCE: connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Posted on Aug 09, 2009
  • 10 Answers
SOURCE: how do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Posted on Jan 19, 2010
I just installed a new xo vision x349nt dvd receiver in my car . My rockford fosgate p3001 amp turns on but the subs doesnt come on but when i would take the base control out and put it back in i can hear...
Make sure and check the RCA wires in the back of your radio that send audio to the amp and make sure that they're connected to the OUTPUT/SUBS RCA's and not an input rca's. Also, check your ground and make sure no speaker wires in the subs are shorted. Try one speaker at a time see if that helps.
May 18, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
I was using bridge on a Rockford P300 and blew my cheap speakers but now my bridge doesnt work. Bought new speakers and want to run in bridge mode is there a fuse inside maybe or did I blow it up?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping.
No internal fuses. Your mosfets are toast. A thumbs up would be greatly appreciated if this answer is helpful to you. using-bridge-rockford-p300-blew-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Apr 07, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
Turns on &off
check ground and power wires also the remote wire. if amp is too small for speakers and pushing max watts upgrade to a bigger amp
Feb 09, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
Hey i was wondering on the model punch 325.1 rockford amp what positive and negitive hook ups do i use for bridged channel.
the amp is a mono block so there is no bridge mode. The 2 speaker terminals are provided for easy connectivity of multiple speakers
Jun 05, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford fosgate p 300-1 amp will not turn on
plug your ground, battery, and remote wires only and see if it turns on when you turn your radio on, if not it must have blown. wiggle or move the connection block(where your wires are connected) and see if it tries to turn on. if so, your leads need to be re-soldered since they tend to go cold(they're not making good contact). But again, if that does not help, then your amp is gone.
Mar 18, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 problem
if amp is mounted to back of the box try and move to in front of box near subs or port. the air movement of the sub will help keep the amp cooled. or you can orer some 12v cooling fans and take back plate of the amp and cool it that way. or you can buy higher quality audio, your choice
Feb 20, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
How do I hook up one sub to my rockford fosgate p3001 amp
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
No sound
Interchange with a known working amp, if work check your wiring and speakers.
Aug 23, 2009 | Rockford Fosgate Punch 300S Car Audio...
Rockford Fosgate P3001 Car Audio Amplifier Logo
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
