Question about RCA P42WHD33 42 in. Plasma HDTV
Problem with RCA P42WED33 picture
Hi, I have my LCD tv hooked up to a dvd player and a suround sound system, my problem is everytime I turn the tv on to watch cable my tv turns on, but the there is no picture for about 3 to 5 minutes there is sound from the sound system, and everything else is working properly.So any help you give me can be greatly appreciated. Teresa
  • sajo Nov 26, 2007
    yellow about an inch vertical an the righthandside
If you have the tv on cinerama mode, it is black. If you use the scroll on picture mode it works
Posted on Nov 22, 2007
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
Sep 02, 2015 | Emerson Televison & Video
Connecting dvd player to a television need a diagram t.u
If you are going to hook up the DVD player to your TV through RCA cords, see the picture below.
Hook up the yellow RCA cord at the Video-in at the back of the TV and the other end at the Video out of the DVD player to get the video.
Hook up the red RCA cord at the Audio-in(right channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Hook up the white/black RCA cord at the Audio-in(left channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Red and white/black RCA cord is for the sound.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 07, 2011 | Televison & Video
I have an older DVD player and have a 32" LCD Vizon HD TV. When we try to play our commercial DVD's it show on the television as black and white with sound and good picture. It seems there is a conflict...
This sounds like a PAL vs NTSC problem.
Check that the TV, the DVD and the Player are all of the same system. If not, some DVD players you can choose / change the output system from PAL to NTSC and vice versa.
You may also change the input system of your TV if it does support it.
Let me know if this helps.
Feb 28, 2010 | Sanyo Vizon LCD-15A2 Television
Hooked up dvd player to tv but no picture
Select Source button from your tv remote keep in AV mode than cheked if you have conected with yellow/red/white rca wire
Jan 21, 2010 | TruTech PM1919BXA1 19 in. LCD TV
I've bought a panasonic sound surround dvd player and want to link it to a sky+ box and tv so that sky will play in sound surround. Can you advise on the wiring configuration please?
look at the back of your tv does it have a audio out RCA jack?
it should do plug in the surround sound into that using RCA cables
if your tv does not have audio out RCA jack then you can
get a adapter which makes scart connectors turn into RCA jacks get that off ebay
plug the yellow line to the tv and connect the red and white to suround sound
but with this there are a few problems sound will only come out when surround sound is turned on and skys sound will never play out the tv
if you switch to a PS3 or something it will not play suround sound
yuo best option is the RCA plugs in the back of the tv
because you have not written the model number of the tv or the suround sound i cant help any further
Jan 12, 2010 | Panasonic Home Theater System System
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
Surround sound dvd player/tv channels are fuzzy
Hi I have an RCA Truflat TV and a philips Surround sound dvd all in one system and a jvc dish system. I have had my surround working up until my nephews messed with it and hooked up a wii system to it. Now I get no sound on my surround sound and I have tried rearranging the cables but I can not get any sound from the surround sound and for the life of me I can not rember how I originaly had it set up. can you help?
Jun 24, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No sound from suround speakers or subwoofer
MAKE SURE THE RCA JACKS ARE RUNNING FROM "AUDIO OUT" OF TV TO "AUDIO IN" ON VIDEO 1 ON RECEIVER, THEN YOU SHOULD HAVE SOUND...(IF THIS IS BACKWORDS YOU WON'T HAVE SOUND.) THAT'S HOW OURS IS HOOKED UP AND WORKS PERFECT.
Sep 08, 2008 | Onkyo HTR500 Receiver
SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
if studio audio facility in tv there [are] hence remaining to install just input channel of output but if there is no having to suround efec,thank.........
www.modifmax.com.
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
RCA P42WHD33 42 in. Plasma HDTV Logo
322 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
