Denon 455 i used to repair t.v`s for a living so i am fairly good with electronics so any help would be nice John
  • 1 more comment
  • john morgans Jan 27, 2009
    when i plug it in i get a click form the transiformer and the red light comes on apart from that nothing.
    Any help would be really helpfull
  • john morgans Feb 02, 2009
    thanks
    any idea where i start looking??
    johncmorgans@ntlworld.com
  • Scott Frye
    Scott Frye May 11, 2010
    What on the Denon isnt working?
    Genius:
  • 1,175 Answers
Typically amps do that for one of two reasons:
1. All the speakers arent connected proper
or
2. One or both of the amplifier output modules have failed.
I dont know if that model uses discrete transistors or STK type units.
Most of those parts are available off the shelf though
Posted on Jan 28, 2009
  • Scott Frye
    Scott Frye Feb 02, 2009
    Hi again,
    There's a heatsink in the unit.
    If there are 1 or 2 black modules mounted to it with 10 or more leads, that right there , is an amplifier module.
    Get the number off that.
    If not , it's power transistors mounted someway to the heatsink.
    Get the numbers off those.
    Please rate my help level too
    Thanks
    Scott
Denon DRA 455 cuts out after a couple of minutes on any volume, wired correctly has it finally died or can it be fixed?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 07, 2011 | Denon DRA-455 Receiver
The power supply has burnt out on my denon dra-455 reciver.
It really depends what and how much burn't up? The only way to find out it to take the top cover off and look inside. A lot of parts in the power supply section can only be replaced by excat parts due to safety reasons. And are you certain it's the power supply that's gone up, and not the POWER AMP section? It could be just one part that started smoking. If any semi-conductor has burnt up, you might not be able to read the code number, in which case you will need the service manual.
SO GET LOOKING INSIDE!
Jul 01, 2010 | Denon DRA-455 Receiver
Denon avr 2308 no subwoofer operation
is the sub in speaker set A and sub in set B?
that was my problem on Denon DRA-455 with Eltax Linear 6.5
May 29, 2009 | Denon AVR-2308CI
Denon DRA-354r
I have traced the fault to the rf amplfier transistor in the tuner "can" It is a 4 pin item with 6JK85 on the encapsulation but have been unable to source a replacement. Can anyone help?
May 27, 2009 | Denon DRA-455 Receiver
Denon 455
Hi John
For sure, can at least get an understanding of what may be wrong. You hear the power relay click in, but perhaps no secondary click of the speaker protection relay.  This is generally caused by a fault condition in the amp, resulting in a DC offset voltage being present in the speaker outputs, then detected by the protection circuit, does not allow the speakers to be connected to protect them from damage.  . How far do you want to get into it?
regards robotek
Jan 25, 2009 | Audio Players & Recorders
Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Jun 06, 2008 | Denon DRA-455 Receiver
 Grubhead
Grubhead
