Question about Maytag MSD2432G Side by Side Refrigerator
Yellowing handles on Maytag side by side refrigerator
Our MSd2432GR Maytag side by side refrigerator exterior handles have turned yellow. I suspect the UV has diminished the white pigments.
What is the fix for this?
    President:
  • Maytag Master
  • 2,651 Answers
Only solution is to relpace the handles, there are 3 parts to each upper, middle nad lower here are teh part numbers youll need 2 of each, both the freezer and refrig are the same parts
61005445 handle upper
61005494 handle lower
61005609 handle main
Posted on Jan 25, 2009
Reset water filter seconds hold jenn
Your owners manual should tell you how to rest these buttons. When your filter button lights up press it once it will ask you to confirm and that's it.
Aug 10, 2013 | Maytag MCD2257HES Side by Side...
I have a Maytag MSD2432GR side by side. I am finding water pooling in the bottom of the Refrigerator side, as well as finding periodic puddles in front of the fridge. What is the cause and how do I fix...
IT MAY NOT BE LEVEL. the fridge has condensation that builds up on it but usually evaporates. you may also have a pinhole size leak in the icemaker line behind the fridge.
Jan 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
The white plastic(?) full length door handles OUTSIDE the refrig are turning yellow on my white, side by side refrig. What can I purchase or use to re-whiten them and make them look clean and white again?
That yellow coloring is most likely a result of the white paint coming off, and the yellow plastic color showing underneath. Other than painting them with a good paint, which you would have to ask a paint expert for the proper type, my suggestion is to replace the handles altogether.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The handles on my white GE refrigerator have turned yellow. Will GE replace them? What are my options to have white handles again?
Hi and welcome to FixYa I am Kelly. I can tell you from many many years of experience and from my very own refrigerator having the handles turn yellow that it does not seem to mater what you use they are just a lighter shade of yellow after cleaning. It is frustrating even from an old salt of 40 + years doing in-home Appliance repairmans' point of view. Mainly because nothing seems to work. I have relinquished myself to just replacing the handles if they are really yellow. Maybe some other expert has found the golden clue of "How to" get rid of the yellow handles. My experience has not been successful.
If you provide me with a Model number I can provide you with a couple of sources for your handles. I do not think GE is going to replace them for you. I have not seen them replace any under warranty for being yellow. They have replaced them when there was shipment damage.
Thanks for choosing FixYa
Kelly
Oct 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The handles on this white fridge have turned yellow. Why?
try to take them off and dip them in a bucket or bath tub of very hot water and bleach and let them sit for about five minutes.
Jul 24, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Door handles have turned yellow and i can not get
Try straight chlorine bleach with gloves on that is. If this doesn't remove the yellow stain you can forget it. You will have to replace them instead.
Dec 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig handles have yellowed
Hey there, check out the link, it brings up a list of parts including the handles. All the parts are for your fridge. Good Luck
seth
http://www.repairclinic.com/Appliance-Parts?s=t-gss25jfmdww+-%3d%3dc226
Jun 26, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Profile Refrigerator model #TXP24PRYE with yellowed handles
Spray with clorox all purpose cleaner and scrub it with hot or warm damp wash cloth.If the handles are plastic, Krylon makes an excellent line of spray paint products that bonds to plastic and adheres to the surface. Most spray paint products only coat the plastic and on a surface like a handle that will be used constantly, is easily scratched or peeled. The Krylon plastic paint bonds to the plastic surface and is very durable. The one down side is if you paint the handles and don't like the results, there is no going backwards, you can't remove the paint once it has cured.
Thanks.
Jun 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Door dhute not opening to let ice fall
on the right hand side of the door chute there is a little metal barrel that needs to be attached to the end of the arm that holds the ice door. this is attached to the spring that opens and closes the door chute.
Apr 16, 2009 | Maytag MSD2732GR Side by Side Refrigerator
GE Side by Side refrigerator door handles yellowing
The brillant person posted the perfect solution. We just tried it this weekend. The plastic composite on the handles is not UV protected plastic, so it yellows or turns brown over time. You can't clean it, as it's a defect due to light exposure. We downloaded a diagram of our fridge and learned how to take off the handles. The top and bottom white portions pop off, but be careful when doing so. We gently lifted them off the metal backing and put a butter knife underneath so we would not damage the plastic. You can then see the clips that hold them in place. Gently pry them and they will pop out. You have to remove the top and bottom pieces first then it will expose the screws that hold the handles in place. You need a star type screwdriver-we found one at Home Depot. The metal strip is a simple backing and will just stay in place. Now, the key is the Krylon Fusion paint-Satin White, like the one person wrote. It's for plastic. Clean off the handles and make sure they are dry. Tape off the portions you don't want paint on and spray them outside with the paint. It dries quickly, but we waited about 8 hrs to put them back on. Just put them back on with the handles first and then the top and bottom portions-they cover the screws. Ours now look brand new! Cost? Only $6.50 for the can of paint and we got it at Walmart. If we had to replace them w/new handles? About $175. Thank you to whomever it was that shared this idea. It really works!
Dec 01, 2007 | GE GSH22JFR Side by Side Refrigerator
Maytag MSD2432G Side by Side Refrigerator Logo
862 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
