Question about Garmin StreetPilot c340 GPS Receiver
My garmin streetpilot c340's screen turns on and then goes black. I have it plugged into my car but it still won't stay on.
  • navincsc Feb 04, 2009
    I've had my streetpilot for 1 year and I now have the same problem. Hope someone out there has a fix. I sure do miss having it.
    Problem Solver:
I found the solution on another blog. He said to try resetting the reset button . It worked. The button is located under the front screen. Remove screen frame by fingernail under the Garmin name. I'm thrilled. navinscs
Posted on Feb 04, 2009
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
My Garmin c340 has won't turn on, screen is completly dark unit is charged
I has the same problem with a streetpilot 540.. It wouldn't turn on, even once charged. There was no reset button under the serial number. However, prise off the grey plastic square plate on the front panel which goes around the screen. ( there's even a little space for your fingernail under the Garmin logo). The reset button is under that plate. Press that with a screwdriver then turn on. My unit turned on once reset.
Aug 10, 2009 | Garmin StreetPilot c340 GPS Receiver
GPS StreetPilot c340 quit working
Plug charger in, and then reset it. Let it charge for awhile before tryng to use it though. It sounds like the battery is very very low. When it is plugged in it still will not operate unless the battery has some charge in it. I hope this helps.
Apr 18, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 won't stay on
blown fuse in your power/charging cable
Mar 21, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot
I had the same issue with mine during a trip. Probably needs to bereset. See page 31 of the users manual on Resetting your c340. Once Idid this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Nov 01, 2008 | Garmin StreetPilot c340 GPS Receiver
Blank screen. Not working at all.
Try to turn it on while it is plugged into the charger and see if it works. if not, you might need to update your software using this website: www8.garmin.com/support/collection.jsp?product=010-00401-20
Oct 22, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin streetpilot c340
Have you tried resetting the unit?
Remove the face cover (GENTLY pry it loose by the fingernail groove directly under the GARMIN logo), press the RESET button, then re-attach front cover... this is covered in the owners manual, also available online at garmin.com /support /downloads
May 01, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
147 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
