Question about Linksys Computers & Internet
Linksys_ext what is linksys_ext
Need to change login and pass word for my net gear royuer wndr3700
If it is set to the default the username should be "admin" and the password should be either "admin" or "password". If they have been changed and you cannot access it, you will have to factory reset it by holding the reset button down for 10-15 seconds then access it using the credentils above.
Dec 09, 2013 | Linksys Computers & Internet
Wharfedale tv settings
By default, the TV stores memory of last settings in its memory ic, when you switch off. By modifying the input devices, you have increased the number of settings to be stored, which might be beyond its capacity to store and it switches to default settings. Try resetting to the desired input and locking the settings.
Aug 05, 2012 | Televison & Video
Why wont my computer recognize my LDHD-UP2 external hard drive?
can you try this sequence
turn off power to both computer and ext drive, after logging off computer
leave ext drive power OFF
connect ext drive to another USB port
turn computer back on let it boot up ext drive is plugged in but no power
once computer stabilizes, then turn power to ext drive on
let me know if this helps.
May 17, 2012 | Computers & Internet
What's your problem?ext memory in the ext jack on rear of unit not recognised check ext memory turn power off then on.
Hello
Turn the set power OFF by unplut it from the AC power wall socket. Connect the external memory after that, Only power ON the set after connecting the external memory.
Mar 11, 2012 | Sony BDPS370 BluRay Player
Lines ring to a certain group and I need to change a phone from group 73 to group 72 - how can I do this?
From Ext 10 or 11>
Dial feature 00>
Hit the left intercom button twice>
The display will show "System Programming"
To remove the Ext. from group 73
Dial #502>
The display will show 'Group"
Dial 3 for group 73
The display will show "Extension"
Dial the Ext # of the phone that needs to changed
Dial 2 to un-assign the Ext from Group 73
To add the Ext. to group 72
Dial #502>
Dial 2 for group 72
Dial 1 to assign the Ext to Group 72
Dial Feature 00 to exit System Programming and save the changes
Be sure to ask me if you need more information
Mar 16, 2011 | AT&T Lucent MLS-12D Phone
I have a WUSB54GC ver. 3 wireless card, that my windows XP system will not detect. I see the card listed in the Device Mgr. with a ?, but I have tried several drivers & none seem to work. I also set...
The driver is listed as available at:
http://homesupport.cisco.com/en-us/wireless/lbc/WUSB54GC/download
It is at the bottom of the list.
Good luck, I hope this works for you.
Mar 08, 2011 | Linksys (WMP54GS) 802.11g/b Wireless...
Problem with WD EXT Network HDD (1TB)
Have you set up the drive as shared on your network?
Apr 15, 2009 | Western Digital My Book Essential 1TB...
Norstar Flash
phone is not programmed for forward busy no answer.
Feb 06, 2009 | Nortel Norstar 16-Line PBX Speakerphone
What type of wire to use bet. ext. antenna and wireless pci card?
20 meters is a LONG way to go with an antenna wire for this application. Generally it is not recommended to extend the wire between the card and the antebba more than 3 meters. You would need to use thick, low-loss, cable that is very expensive. But if you must, computer stores sell extension cables.
http://www.compusa.com/products/product_info.asp?product_code=50347352
Nov 05, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
131 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
