Question about Philips TSU3000 LCD Touchscreen Remote Control
I have a Phillips Pronto TSU3000. No manual on how to program remote or other devices like - TV, suround sound, cable, etc. HELP. thx
    Problem Solver:
  • 10 Answers
All the answers are here :-
www.remotecentral.com
Posted on Jun 29, 2009
What code for ge universal remote 24991 operates phillips dvp 3982/f7?
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Aug 15, 2014 | GE 24991 3-device Remote remote Controls /...
Pronto tsu3000 frozen
Check the remote control for its infrared emission. Check it with brand new batteries. If found faulty, clean the remote control's internal circuit board. Just click this link to know more about cleaning procedure. Pull up older posts there.
Sep 25, 2012 | Universal Remote Control Televison & Video
I have a g e universal remote and i dont have a code for it to work on a phillips tv
Good day!
This are the 3 digit codes for your Phillips TV. 003, 004, 006, 008, 062, 068, 069, 074, 075, 076, 086, 087, 089, 133,
This are the 4 digit codes for your Phillips TV. 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
How to enter codes manually:
  1. 899 Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
  2. Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
  3. Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
  4. Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
  5. Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
I hope this information will be helpful.Thank you and good luck.
Apr 23, 2011 | Universal Remote Control GE174Universal...
Have a new Phillips 42" lcd tv. my cable box remote has been working intermittently. However the white light near the remote sensor on the TV blinks whenever I use the cable remote. after changing bat
your TV and, your cable box both "see" a series of invisible (infared) flashes of light like morse code these flases tell them what to do.one answer is to: buy a universal remote so that you can program a button for each device then when you want to control the cable box just push the "cable" button and, then volume etc. to turn your tv off push "tv" then "off" the service man was right but he should have explained this to you
also your cable remote may be programable to work with your tv like a universal remote check with your cable co.
May 22, 2009 | Televison & Video
Need code for phillips remote
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 09, 2008 | Philips Televison & Video
Programing
Hope this helps :)
Jun 09, 2008 | Philips Universal PH301S Remote Control
Phillips pm3s lost code book:
Hope this helps :)
May 31, 2008 | Philips PM3S Remote Control
Philips TSU3000 LCD Touchscreen Remote Control Logo
210 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
