Question about Whirlpool GU2400XTP Built-in Dishwasher
Start Button My grandson peeled the start button off of my dishwasher and it was the button was misplaced before it was stuck back on. Can these buttons be purchased anywhere?
    President:
  • Whirlpool Master
  • 2,651 Answers
Youll need to replace the entire console, the "sticker" is not sold seperatly
Posted on Jan 25, 2009
I am getting a 5H in the panel where the time cycle usually is and when I hit start it won t start
I think your dishwasher is in delay start mode. Some dishwashers can be set to start at a later time say for instance while everyone is sleeping. See if your control panel has a button that says delay start. If YES--just keep pressing it until it clears. Some go as high as 12H which is a 12 hr delay.
Feb 28, 2015 | GE Dishwashers
Frigidaire error code of er slean s
Main Control Board hasdetected a stuck key or a key pressed for more than one minute. Checkconnection from keypad to Main Control Board. If correct, replace keypad. Iferror still exist, replace Main Control Board. (Note: washing, drying, andclean s may appear in display when error code is present)
Aug 01, 2012 | Dishwashers
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Oct 08, 2011 | Maytag MDB7100AWB Dishwasher
Hi I have a Whirlpool dishwasher ADP5740, Condenser. My grandson pressed the start button before I had set a programme, now the light is stuck on the pre-wash and the start light is flashing and it...
If you have a reset or cancel button try that. Look in your manual for a reset
procedure or troubleshooting section. It is just stuck in a cycle and needs to be reset
or cancelled.
Marty Mouse just a housewife.
Jun 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Normal wash cycle constantly blinking no other buttons responding dishwasher wont start
one of 3 things is happening, either your "start" button is not funtioning, the door latch is not operating, so the uint doesnt recognize the door closing there fore wont operate, or the "normal" button is "stuck"( electronic switch possible shorted)
the fact that you cant get any other function out of it leads me to believe that you have a stuck button/shorted keypad. this is not available as a seperate part and requires replacing the "console with active overlay"
Mar 03, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Error Message 'Er' on frigidaire dishwasher
I had the same problem. I pressed the "Start Cancel" button, kept it down, then pressed "Rinse Only" button. The display then went clear. I pressed "Start Cancel" again, then "83" showed up on the display. I let it run its cycle, then it corrected itself. A little scary, but it worked. This answer board is great!
Jan 29, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
P button stuck
The P button is a part of the control board. You should take apart the control board and see whether the P switch was just stuck and you can fix it or you should replace the unit. Good luck!
Sep 10, 2007 | Smeg 24 in. DWF614SS Stainless Steel...
The "Rinse Only Button" will not function even after going through the "Cancel" cycle.
br, sounds like you have a stuck keypad. This would be the only reason it is switching to a different cycle. Catriver..post back.
Oct 01, 2006 | KitchenAid 24 in. KUDS25 Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
153 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
