Question about Samsung TXN3071WHF 30" TV
Hourglass shape on left and right side-ballpark repair price please
From any source the picture has an overall hourglass shape. the left and right sides are curved inwards. i've heard this may be a power supply problem. i know i am going to have to call a technician-and i know i'll have to pay for it since it's way out of warranty. so without telling me "well we don't know until we bust it open and diagnose it", someone please give me a ballpark figure for repairs. less than $500 or more? pretty simple, but every time i post one of these questions no one wants to mention a price. ballpark is all i want. $1000? $500? $200
  • 1 more comment
  • poe diddley Jul 14, 2007
    thank you i appreciate your honest response. has been hard on other forums to get people to name even close to a price. hopefully you are correct and i don't have other problems. i will try to post an update if/when i get it fixed
  • poe diddley Sep 01, 2007
    service tech came and picked it up today.
    he tried to adjust it here, but didn't seem to be able to get it.
    he called to his shop and they found a few samsung bulletins on this particular tv that mentioned some replacement boards
    hopefully i can get it fixed without the price getting too ridiculous, he said that if it ended up just being a diode or something simple i was looking at around 180 so hopefully that is indeed the case. will update when i hear back from them in two weeks.
  • poe diddley Sep 15, 2007
    repair shop called today. total bill is $200, which includes in home service attempt from a shop that's about 40 minutes away.
    haven't seen it actually working yet, but it should be delivered on monday-will update with my opinion of picture quality when it arrives.
  • 432 Answers
The shape your seeing is called 'V Bow' and 'Pincushion' which needs to be calibrated again. Theres probably a diode that went out. The tech can open it up and adjust the angles back. I wouldn't charge over $100-$150. Shop around for a good repair tech. Good Luck poe_diddley.
Posted on Jul 13, 2007
SOURCE:
It has an hourglass shape when first turned on but
Your TV set has trouble in its "pincushion correction" circuitry, which corrects distortion so the picture is straight on the screen. Unfortunately, it's not possible to pin the trouble down to a specific part without having the set for troubleshooting. Since the trouble clears up after the set's on for a time, it's probably due to a faulty capacitor or intermittent solder connections. Because of the troubleshooting skills and tools needed, you should let a professional service shop handle the repair. This kind of problem is relatively inexpensive to repair (at least parts-wise; I've been out of the repair business for a while now, and have no idea what kind of labor prices shops are charging) and would not cost nearly as much as a replacement TV.
Sep 24, 2009 | Panasonic CT-35XF53 35" TV
I have a Panasonic CT-32D31 TV and I've been noticing some shrinking and curvature of the picture from both the right and left sides. Is this something that can be fixed quickly, easily and most...
Your symptom sounds like a damaged component in the pincushion circuit.
When this circuit fails the picture will have an hourglass shape to it with black in the middle on the sides, or you will see square objects as hourglass shapes.
I would recommend that you have a local service center diagnose the set for you and give you an estimate of the repair.
I have seen this type of repair run from $150.00 - $200.00.
The cost of the repair or replacement of the set is completely up to you. I would most likely recommend that a replacement may be in order, as most television sets are becoming cheaper all the time.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Jul 09, 2009 | Panasonic CT-32D31 32" TV
THE PICTURE HOUR GLASSES IN SHAPE
If your colors line up in the middle of the set and at the top but the picture is concave then you may have a faulty component in the pincushion circuit. When this circuit fails the picture will have an hourglass shape to it with black in the middle on the sides, or you will see square objects as hourglass shapes.
I have seen this type of repair run from $250.00 - $350.00.
Jul 09, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Sony 53 inch projection screen with hourglass picture
If you are familiar with TV repair, have electronics basic knowledge, good soldering skills and tools then check dry (cold) soldering joints at D board of this TV. Resold all lose connections there and check picture.
Still no joy then you need to replace D board.
Feb 25, 2009 | Philips 60PP9202 60" Rear Projection...
I CAN'T PULL THE T-SHAPED THINGS IN THE RIGHT ORDER .
ok u have to go the far right one first then the 1 nest 2 the far right. the the other right, then the other left.i have that game.
Feb 09, 2009 | Nintendo The Legend of Zelda: Phantom...
Picture is smaller, has hourglass shape, no sound
Took back off, removed control board and inspected for bad solder joints. found no obvious problem. Cleaned and reinstalled. Working ok now. I'm crossing my fingers.
Jan 27, 2009 | Philips Magnavox TS3260C 32" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Hourglass Picture
Pulling in from the sides usually results from poor regulation or width problems related to the horizontal circiut. These are not usually repaireable by a non technician.
Aug 06, 2007 | Toshiba 27D46 27" TV
Picture is hourglassed shaped
your unit has a problem in horizontal circuit particularly deflection and pincunshion circuit. pls have it check by a qualified service technician.
Jan 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Open Questions:
See all Samsung TXN3071WHF 30" TV Questions
Samsung TXN3071WHF 30" TV Logo
205 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
