Question about Panasonic Shiatsu Massage Lounger with Electric Reclining Ep790k
Pansonic EP578 massage lounger
Need schematics roller will not move
3 Suggested Answers
SOURCE: Instruction manuel for massage lounger panasonic ep 1260
Hi, Went to Google and instruction manuals. From there, I made the proper selection.
Posted on Jan 31, 2009
vetteman3002
  • 2299 Answers
SOURCE: I need to find a
201-391-3700 These guys advertise that they repair any kind of electrical problem. And the problem with your chair is more than likely a switch. If they can't help you they will be able to tell you someone that can.
Posted on Nov 09, 2010
Need power cord for shiatsu model 8173
where can I find a cord for my shiatsu recliner, model #8173, thank you
Oct 10, 2013 | Panasonic Shiatsu Massage Lounger with...
In reference to electric massage chairs, what are nodes and rollers?
These are parts of the massage chair that are designed to imitate human fingers and hands. They target specified areas of the user's back and can move in an assortment of ways; which are preprogrammed into the mechanics of the massage chair.
Aug 06, 2012 | Furniture
THE MODEL IS EP578.ROLLERS DONT MOVE BUT MOTOR IS FUNCTIONING.LIGHTS IN THE REMOTE ARE BLINKING ALL TOGETHER THEN THE MACHINE STOPS.
I found with my Panasonic EP578 that, if the lower photo sensor limit switch gets too dusty, the massage mechanism will travel downwards past the normal range of motion and the electronics will time out because the unit did not get a down limit sensor signal & reverse direction and proceed back to the upper limit switch in time. With the device unplugged, I simply removed the grommet screws and opened the fabric backing. Then I removed the units cover and Then blew out dusty photo sensors with compressed air. Then I swapped the red and green, 2-pin mag clutch coil connector plugs so that when I switched the unit on again I could make the unit travel back up to about, the scapular position. The reason that this is possible is that when you first start a normally working machine, the first thing that happens after the motor turns on, is that the motor clutch for the mechanism that provides the neck and vertebral massage balls, also energizes. I figured that I could get the voltage at that connector to energize the rolling clutch to get the unit back up again (as you can't move it by hand). Then I turned the unit off (while stile in cycle) and the swapped the mag-clutch coil connectors back to their original position. Re-starting the machine causes the moving massage mechanism to go through it's Power On Routine which realigns everything to it's 'Home' position and ready to run a fully functioning cycle. Remember to unplug the machine when working on it and keep all fingers, necktie, hair, jewelry from moving mechanism when it's moving to avoid damage to the machine and bodily harm to yourself!
P S here's a link to a service manual .pdf download for the Panasonic EP578:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwj_zpzD_NvQAhVpqFQKHb6EBbgQFggeMAA&url=http%3A%2F%2Fblog.lincomatic.com%2Fwp-content%2Fuploads%2F2013%2F01%2FEP578.pdf&usg=AFQjCNESCMv3PGtxbXCJfn-RHnEBwiQoIQ&sig2=2t3ZqNxLVT8Y4RJ6nKolmA
Mar 21, 2011 | Panasonic Shiatsu Massage Lounger with...
Finding KSI owner
I found the guy by basically google it.
Sep 18, 2009 | Panasonic Shiatsu Massage Lounger with...
Jan 30, 2009 | Panasonic Shiatsu Massage Lounger with...
The power led light keeps flashing
Hi.
Give it a good 'knock' on the back (hard surface). You might hear a clink sound. I think it's when a cog gets out of line. My chair is fine now. You'll notice that the rollers start moving back to the off setting. So if it goes off and they are in the middle or top then it's stuck and needs a thwack!
Dec 01, 2008 | Homedics SBM 300H Therapist Select Shiatsu...
Holding question
First, select a wide massage area, and use the roller surface. Slowly movethe head of the massager over the massage area in big, wide circles. Then,for areas of soreness or stiffness, change the massager to the proper mode (Some massagers have two levels) . Push down on these massage areas for about 5 to 7 seconds for eachsore spot. Finish with the roller surface again, moving the head around theextended massage area in large, uniform circles.
Aug 27, 2008 | Jobri Dolphin Handheld Massager
Panasonic Shiatsu Massage Lounger with Electric Reclining Ep790k Logo
107 people viewed this question
Top Panasonic Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Panasonic Furniture Expert? Answer questions, earn points and help others
