Question about Samsung HP-R5072 50 in. Plasma HDTV
Tv powers itself on and off
I've had the set since Christmas and this problem just started. After a variable length of time, the set will power itself off and then back on. The routine lasts about 10 seconds and once it begins, it will continue every 5-8 minutes. I have done a reset, unplugged the power for an hour and taken the batteries out of the remote trying to pinpoint and clear the problem. Any ideas out there? The set does feel warm to hot on the back panel...but I'm not sure what the standard temp would be for the set while operating normally.
  • david welsh Jul 13, 2007
    this is model LN-S2651D
    Sergeant:
  • 274 Answers
You have a problem internally caused by heating (set is on for a few minutes) and then cooling (set turns itself off for a few minutes). Most likely a "cold solder joint" or a bad component on the power supply board. Locating it yourself can be difficult. If still under warentee you'll need to take it in or have them come out. (whatever is in your contract) They'll simply replace a circuit board instead of trying to fix it.
Posted on Jul 14, 2007
  • Anonymous Jul 14, 2007
    As far as opertating internal temps go, around 140-160F. Some run lower, some run much higher, depends on how smart the design team was. Componets don't last a long time under high temps. A bad solder job can actually raise the temp sometimes because of higher electrical resistanace in the circuit. Your problem: Circut gets hot, breaks contact, gets cold, reconnects contact.
SOURCE:
Emerson TV Model #LC401EM2F Fix after lightning?
Lightning damage on LCD TV's can be a doozie. You really need to get it checked out by a qualified technician. I've repaired several TV's hit by lightning, most of the time the damage was limited to the power supply board. However, it is possible that multiple boards were damaged. If multiple boards were damaged, it's not worth repairing the set.
Jun 02, 2012 | LG Televison & Video
Acer Television AT2703 Flipping through inputs automatically
Seems like your set now has a poltergeist in it after all these years. If set turns on an doff by itself and works erratically there could be a power supply issue since it supplies the juice for the various areas to do their thing. If PS is messing up, so will other sections of your set.
Apr 15, 2017 | Televison & Video
We've had a 42" LCD/HD
Tries tv unplug,replug it back like about an hour later.Most of the times tv will resetting itself back to the factory setting and will work again.If still have the same problems,tries pushes the power button on/off a couple times for trying to fire up the tv Tuner signal board,these off/on tries work with many LCD/Plasma HD tvs.But this kind of problems,eventually u have to change the tv Tuner signal board sooner or later.Because the tv Tuner signal board it is dying,and this solution is just a temp fixed for the delaying it for awhile.
May 25, 2011 | Televison & Video
I have a new tv fro wal mart and i"ve had it for
Tries unplug,replug it back like about an hour later.The tv now,will resetting itself back to the factory setting.The tv now should work.If not the power LED light indication on the LCD screen panel flashes or take 2 or 3 mins picture to come on.The problems is the tv power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.If tv was bought and it under a year old,call Samsung Corporation for a warrenty repair.
Nov 24, 2010 | Samsung LN-T4665F 46 in. LCD Television
Does any one have the specs for a solid audio F2500D amplifier?
Power Output
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
RMS @ 1 Ohm: 4000W x 1 Ch @18v
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
Nov 13, 2009 | Car Audio & Video
Goodmans 15" LCD keeps switching itself on
I'm having the same problem with the same TV that I bought my daughter for Christmas.
I haven't tried this myself yet, but it is suggested on another website that the TV is switching on to look for software updates during the night. Apparently you can switch the auto-update feature off, which fixes the issue.
G
Jan 02, 2009 | Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Samsung HP-R5072 50 in. Plasma HDTV Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
