Question about Technics SA-EX140 Receiver
How to hook up speakers
I have two Bose 201 Series IV speakers. They are not hooked up correctly only the speak hooked up into "A" works. The other speaker was hooked up into "A" but no sound from that speaker.
SOURCE: I hooked two Receivers up in series.
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Posted on Apr 30, 2007
SOURCE: Speaker Hook Up - Non-Technical (single) Female
bought the same amp second hand and had same problem as there are two seperate amp chips inside one for front speakers and one for the centre and rears it could be the actual amp chip that drives the front speakers has died as there is no built in speaker protection so over driving these speakers will result in the amp chip blowing . it may be something simple but it was not on mine had to buy new amp chip and solder in that sorted the problem for me !
Posted on Oct 02, 2008
dunnbiker
  • 8546 Answers
SOURCE: How do you hook up the audio from Visio flat panel to SA EX 300
Wild guess. Is the TV volume turned down and its output set to variable instead of fixed?
Posted on May 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Posted on Feb 06, 2010
SOURCE: The amplifier,will produce no sound.It
replace audio ic amplifier
Posted on Jul 27, 2011
Not sure of how to wire these speakers ( internal ) Bose 901 series iv
Found on Google Search: "bose 901 internal wiring" You must first identify which series you have. The first two series were acoustic suspension, and used nine 8 ohm drivers in a series/paralel configuration. Series III through VI used nine .9 ohm drivers all wired in series. Series III and IV had an additional terminal for use only with the Bose Spacial Control Receiver. Series III through VI are easy to identify, as there are three ports sticking out the back of each enclose. The 1st two series have no ports.
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
I just unhooked my speakers to move them. i hooked them back up and i have no sound now.
Make sure you hooked thim into the correct jack. May be in the Mike or input jack. Done the same thing a few times
Aug 16, 2010 | Bose Companion 2 Series II Multimedia...
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
How can i hook up my 30gb Ipod to my Bose 901 series VI and i have it hooked uo t couple of yahamhas
There has to be some amplification in here somewhere. Any single amplifier will not work correctly with the Active EQ for 901's applied to non-901 speakers.
Any MP3-player device with at least a headphone output can feed any standard audio device that has a Line Level input (other than "PHONO") once the output is adapted to fit the input.
Apr 25, 2010 | Bose 901 VI Main / Stereo Speaker
Can I hook my TV directly up to Bose 201 speakers?
It depends on the TV audio output connections. Most TVs have low level audio outputs (RCA Jacks) that require a amp but some do have external speaker connections. You will have to refer to your manual or check the back of the set.
Nov 25, 2008 | Audio Players & Recorders
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Left channel
can you give me more info about your problem... is this a speaker system only or complete with amps. because you said u tried with other amps..
Dec 16, 2007 | Audio Players & Recorders
Cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
Technics SA-EX140 Receiver Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
