Question about Uniden Cordless Phone
I have GE 5.8 GHz model 28021EE2-A with no user guide
I do not know how to set up menu, ringer tones, display, anything. Can you help?
    Problem Solver:
  • 16 Answers
Here is a website with the manual for the 28021EE2-A phone by GR...
http://www.home-electronics.net/ge/pc/IB/28021EE2_IB.pdf
All GE phones are now supplied by Thompson Electronics INC.
Posted on Jun 20, 2009
If you don't have users guide then just bech maro that product........
Posted on Jan 25, 2009
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
My phone ringer is off and I don't know how to turnit on
You may follow the steps below.
2. Press mute/program button to enter the menu. SET RINGER 1HI 2LO 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2 or 3, or use the caller ID-volume
4. Press the mute/program button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
May 12, 2011 | GE Lands Phones
Cannot program, menu stuck on Spanish, cannot access main menu from mute/ok button
I know this should be a MUCH more techie answer, but have you tried just asking a nearby Mexican to help you? Just a thought.....
You say you cannot get to the menu from the mute/ok button?
What happens instead?
FROM DA BOOOK looks pretty clear to me.
Handset Setup
1. Make sure your phone is OFF (not in TALK mode).
2. Press the mute/menu OK button to go to the main menu.
3. Press CALLER ID-VOLUME ( 6 or 5) button to scroll to HANDSET SETUP.
4. Press mute/menu OK button to confirm and you may program the following items: Language, Handset Name, Ringer Tone, Ringer Volume, VIP Melody, Key Tone, Set Day/Time, Equalizer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
NOTE: During programming, you may press the END/cancel button at any time to exit the sub-menu and return to the menu.
Language
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the SET LANGUAGE sub-menu.
2. Press mute/menu OK button to enter the menu. SET LANGUAGE 1ENG 2FRA 3ESP shows in the display.
3. Use the touch tone pad on the handset to select 1ENG, 2FRA, 3ESP, or use the CALLER ID-VOLUME ( 6 or 5) button to scroll to the desired language. English is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the selected language shows in the display.
Apr 29, 2009 | Uniden Cordless Phone
Set call rings
From the manual:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
Apr 26, 2009 | General Electric 28811FE2 Twin Cordless...
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Turn off ringer
here's what my instructions say about turning off the ringer:
Ringer high/low/off Shortcut
Apart from the setting in the main menu, there is a shortcut to set the ringer. Make sure the phone is OFF (not in talk mode).
1. Press the #RINGER/PAUSE button to go to the RINGER VOLUME menu. RINGER 1HIGH shows in the display. 1HIGH is the default.
2. Use the cid/vol (- or +) button or the touch-tone pad on the handset to scroll to 1HIGH, 2LOW, or 3OFF.
3. Press the #RINGER/PAUSE button to save your selection. You will hear a confirmation tone.
Jan 21, 2008 | GE 25951EE2 Phone
GE 25951EE2A phone
1. Changing The ring tones
You can choose ring tones (01 - 03) or melodies (04 - 13).
Press the Menu/Mute button until ringer tone 01 shows in the display. 01 is the default.
Use the cid/volume ( - or + ) button on the handset to select from 01 to 13.
Press Menu/Mute to save.
Nov 05, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
588 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
