Question about Klark Teknik Dn410 Dual Parametric Equalizer Eq
Klark dn410 output balancing transformers
We wish to upgrade factory DN410 with Balanced Outputs via upgradable output transformers (balancing transformers)
I have a flat screen tv the picture work's but no sound the model number is gv47lfhdtv10a
If it is connected to external speakers, then make sure they are on the correct outputs terminals for the mode you are in. Most TVs have several outputs for speakers. Quickest method is to move them to the other outputs until you get sound.
if they are internal speakers, check your balance settings to make sure they are not accidentally balanced off.
Nov 22, 2014 | Televison & Video
Trouble during the upgrad of lexicon MC-12
Try on a different computer , if it still get stuck at the same point bring the amp to sevice shop, they will reinstall the firmware
Mar 30, 2008 | Lexicon MC-12 Balanced Amplifier
How dso I connect a seperate mixer to a Behringer B215D powered speaker
Use the two balanced outputs, intot he inputs on the back of the speaker, 1/4 inch jack should fit.
Alternativly you can do the same via xlr, for a balanced connection.
Jul 28, 2014 | Behringer Xenyx 1202 12-input 2-bus Mixer...
Europower PMP5000, In the Front Panel there is a Main 1 & Main 2 output, can I connect both to 2 Amplifiers so I have four independent outputs or 2 Stereo outputs? Can I Use these two outputs + mon 1...
Yes, you can use both the main1 and main2. They are independently driven and please note that they are PSUEDO balanced drives... that is the cold side of the balanced line is NOT driven as a complement, but is merely returned to signal ground by a 120 ohm resistor. This CAN cause hum problems or noise pickup depending on the connected equipment and ground loops. Best to run this into amps/speakers thaat have TRUE balanced inputs and also keep the power source the same for all devices.
Nov 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Yes how to set up to an amp
There are two balanced outputs from the mixer as well as two RCA outputs (right & left). The simplest connection would be to run RCA cables from the RCA mixer output to the auxiliary input on an amp.
If you want to use the balanced outputs from the mixer, you will need adapters (or cables with correct plugs) to go from balanced conectors to RCA or 1/4 " inputs on the amp.
More info, let me know.
Charlie
Mar 27, 2011 | Numark CD Mix2
Flhtci 2000, 103screamin eagle upgrade,fron of motor jumps at low idle,more than i think it should,bolt broke?rubber mount wore out?
It could be a problem with your rubber front engine mount or it could be that the engine is no longer balanced like it used to be. Check the front engine mount for cracks or any faulty condition.
Now, from the factory, the engine is roughly balanced so as not to shake too much. To do this, be weigh the pistons, rings, wrist pins. Then the factory drill large shallow holes in the flywheels to "balance" the assembly. Now,when you install the upgrade, you changed the piston size drastically and if this included a "stroker" crank, the crank may not be balanced as closely as the original. Also, the camshaft was probably changed. A more aggressive profile camshaft will cause the engine to idle just a bit more rough as well.
Stock engines are designed to idle smoothly. High performance modifications usually do result in the lose of this smoothness.
Ride Safe.
Steve
Jan 16, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
How would you connect a Roland Space Echo direct into a Behringer 2642a mixing desk? Have tryed all inputs/outputs with nothing. Could this be because the mixing desk has ballanced ins/outs and the Roland...
In order for this to work, you need what is called an "insert" cable. This will have a balanced 1/4" connector on one end and 2 1/4" mono-connectors on the other. The balanced connector is also known as a TRS connector (Tip,Ring,Sleeve). You should have "insert" jacks on the mixer. Place the balanced connector into whatever insert you wish to use (usually this is inserted into the main insert). One of the 1/4 plugs is for input, one for output. I don't know which is which for your specific unit, you will have to experiment. Keep us posted. Dan
Jun 12, 2009 | Behringer Audio Players & Recorders
I have a avr-5808CI, when I hook up my bluray player with hdmi cable the blu-ray says 7.1dts hd and my system only outputs 5.1 dolby. I know you need 7.1 analoge out but is my system so obsolete. Is there...
no way to upgrade your pre-amp, but you can just use some simple little RCA Y-Splitters on the rear outputs to essentially give you 4 rear outputs to your amp like with 7.1.
however, true 7.1 each signal is unique.
at some point when it comes time to upgrade, check out Outlaw Audio. They make killer stuff at factory direct prices.
http://www.outlawaudio.com/products/990.html
Feb 27, 2009 | Audio Players & Recorders
Terratec phase 22 problems with getting stereo sound
You must make stereo cable (adapter), from 2 mono outputs to 1 stereo.
Jun 16, 2008 | TerraTec Electronic PHASE 22 Sound Card
Klark Teknik Dn410 Dual Parametric Equalizer Eq Logo
53 people viewed this question
Top Klark Teknik Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Klark Teknik Audio Player and Recorder Expert? Answer questions, earn points and help others
