Question about Zyxel P660HW-D1 Router
Lost username and password for router
I want to forward ports for this I need access to my router but have mislaid my password and username. I live in spain and my ISP is Telefonica. Can you help?
Les Swann
    Problem Solver:
  • 15 Answers
To reset the password on the router, switch it off, press and hold the 'reset' button whilst switching the power back on. Keep holding the reset button until all of the LAN lights blink, and your router will be reset back to the way it was when it left the factory.
This only applies to get round the settings installed on the router. You will have to input all the telefonica settings again so that your router can connect to the internet. Resetting the router will not solve any problems regarding telefonica passwords or user names - for this, you (or the account holder) will have to contact telefonica directly.
I hope this helps you.
Posted on Jan 28, 2009
I cannot get my ps3 game to work. it says to consult my routers user manual to enable the setting in the games booklet. i cant because the manual has been lost. it requires a UDP port 9301. and i need to...
You'll need to setup port forwarding on your router.
From a computer use an internet browser such as Internet Explorer.
Assuming the router is using default settings.
1) In the address bar type in 192.168.1.1
2) You'll be asked for a username and password. Username is 'admin' and the password is 'password', no quotations.
3) Click on 'Port Forwarding / Port Triggering' on the left side bar.
4) Click on the Port Forwarding radio button.
5) Click the 'Add Custom Service' button.
6) For Service Name call it something meaningful, such as 'PS3.
7) For Service Type choose 'TCP/UDP'.
8) For starting port and ending port use '9301'.
9) For server IP use the IP address of the PS3, you can get this in the PS3 menu under Network Settings.
10) Click Apply
UPnP is supported by your router. On the left side bar, click 'UPnP'.
Feb 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Apparently i need to open ports for xbox live any help?
How to Open ports on your router for xbox live. (wrong forum) If your NAT (Network Adress Translation) is "moderate" or "strict" you will only be able to play with people who have a open NAT. You can find out what you are by going to "System" on the Xbox 360 dashboard, click on "Network Settings" and test your connection. Upon passing all tests it will tell you your NAT status at the bottom.
If your using a router or other gateway device you need to port forward certain ports.
Open up your start menu, click on "Run..." type 'Command' once the command window comes up type, 'ipconfig /all' take note of your "Default gateway", you might need to scroll down.
Open up a browser window. Internet Explorer, Firefox, Opera...
Type your default gateway and it should access your router.
You may have to enter your username and password, if you havent changed it, it should still be default, 'admin' for both username and password, sometimes 'Username' and 'Password' if you cant figure it out contact the maker.
First off make sure UPnP (Universal plug and play)
Now, this varies for all routers, but usually its under Advanced Settings or something along those lines, some even have a port forward tab, others are called application sharing or using.
Then open ports, or open application ports or assign application/game.
The following ports must be opened...
UDP 88
UDP 3074
TCP 3074
..Sorted.
Any troubles email me.
If your default gateway doesnt work, or you cant get into your router go to www.portforward.com and look up your router.
Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Feb 01, 2011 | Buffalo Technology WHR-G54S Wireless...
Blitzz wifi router default userID and password?
The default is admin and admin...
If that doesn't work, the reset button will clear the stored login information and reset your router to factory default.
Make sure you hold that button for about 15-20 seconds before you release it. After you did this, you can access your router again via the default IP address2.gif of 192.168.1.1
The default username and password for your Blitzz router are both "admin".
Don't forget that all your personal settings will be erased as well (wireless security2.gif, port forwarding etc.
Nov 08, 2009 | Blitzz Technology (BWA611) Router
I have a BEFSR41 Lynksis router and when i try to connect to xbox live it tells me my NAT type is Moderate and it should be Open. How do i change it to Open?
Xbox LIVE has default ports that needs to be forwarded on the router.
To forward the ports, access the setup page of the router. In your internet browser's address bar type 192.168.1.1.
Leave the username blank and then the password is admin.
Go to the Applications & Gaming tab, click Port Range Forwarding.
In the application field, type XBOX LIVE.
Start End Protocol
53 53 Both
3074 3074 Both
80 80 TCP
88 88 UDP
In the IP address field, type the IP address of the XBOX. Check the enable button. Then save settings.
Sep 26, 2009 | Computers & Internet
Wont sign me into xbox live even though my router is like green
Hi, Follow the steps below to open ports on the router for XBOX:
1. Open a browser (Internet Explorer, Mozilla Firefox or Safari) on your computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router (Username = admin and Password = Password unless you have changed it).
4. Click on Port Forwarding under Advanced.
5. Click on 'Add Custom Service' button.
6. Specify any name for the service (XBOX1).
7. Specify the Start and the End Port as 88.
8. In the server IP Address specify the ip address of the X-box.
9. Click on 'Add' button.
10. Follow the same steps to open the port 3074 and 53 and use the name as XBOX2 and XBOX3. Click Apply.
Sep 04, 2009 | NetGear WGR614 Wireless Router
Dont know how to set nat type to open
For you to be able to open the NAT on the router you have to open or forward the application port on it. This router has a graphical interface where you can configure port forwarding, access http://192.168.1.1 (default) username blank and password is admin. Now look for port forwarding and open the port for your application.
Jun 29, 2009 | Linksys Wireless-N WRT150N Router
How to reconfigure router
you may need to reset to restore the defaults.
the the default username: admin and password: admin
Jan 16, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Port forwarding
Hi!
Do you know how to access the router's web ui via Internet Explorer?
If it's the default then follow these steps:
1. Open IE then type http://192.168.1.1 (username: (leave it blank)/ password: admin)
2. Click at Applications and Gaming tab
3. Click at Port Forwarding sub tab
Hope this helps!
May 03, 2008 | Linksys Wireless-G WRT54GS Router...
How To Make a DMZ
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding, as described in How is Port Forwarding Configured? However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear MR314 802.11b
Zyxel P660HW-D1 Router Logo
1,174 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
