Question about Royal Office Equipment & Supplies
My royal alpha 600 typewriter's striker is not working, how do I fix it
5 Suggested Answers
JUSTOLDJIM
  • 478 Answers
SOURCE: TA Royal 420 (Electric Typewriter)
I dont know where uou can find one try e-bay
Posted on Jun 14, 2008
  • 329 Answers
SOURCE: Striker Sticking When Erasing. Brother ML100 Typewriter
Sounds like the gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not movving, or moving slow that under power you won't see.
Posted on Aug 28, 2008
squipps
  • 204 Answers
SOURCE: Need to re-set margins on Royal electric typewriter
Use the green code key with the rm and lm keys.
Posted on Dec 19, 2009
  • 300 Answers
SOURCE: My Royal Alpha 2001 typewriter has been unused for
Hi!
I'm going out on a limb here.
I assume the carriage returns but the line does not advance. Close?
- There is a setting for the linespacing which is either 0 (zero), or 1, or 1 1/2 or 2
Likely, this has been inadvertently moved.
- Also, there is a way of disengaging the linespace mechanism to allow typing to be made on unevenly space forms. This might have been moved.
Please feel free to contact me anytime.
Posted on Feb 14, 2011
Installing cartridge ribbon on a Royal Alpha 2001 electric typewriter
The cartridge should lift up and off then the new one is put in
Jul 03, 2017 | Royal Office Equipment & Supplies
No power to royal alpha portable typewriter
If the motor makes any noise at all when you turn it on, the belt is probably broken.
Mar 19, 2013 | Royal TA Adler-Satellite 80 Typewriter
How do you remove the ink cartridge from a Royal Alpha 2001.
If memory is working there is a lever with a red end just to the R. of the ribbon, pull it toward you untill it stops the ribbon cassette should lift out.
DickyO
Mar 31, 2012 | Royal Office Equipment & Supplies
I have a Royal Alpha 115 with prospell and all of a sudden 1/2 dozen won't type in small case but continues to type in capitals!
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, then it should be ok. If not try it again.Check to make sure no pedals on the printwheel are bent.
Hopes this helps!
Feb 08, 2011 | Royal ET640 Typewriter
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
Royal alpha 600 won't type. New ribbon, all looks fine. No type at all.
There is a grey lever on the right side of the carriage that strikes the printwheel hammer. It always breaks. You can purchase this part for a few bucks and install it yourself. I have a few of them. Verify if it is definitely cracked and I can sell you one for $ 13.00 including shipping.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 26, 2009 | Office Equipment & Supplies
336 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
