Question about Proform Exercise & Fitness
Proform treadmill motor overheating - Proform Exercise & Fitness
jgwhomeequip
  • 1902 Answers
SOURCE: proform treadmill 580si motor is not working
Recheck your wiring and check your ground. If all that checks out then triple check your control board. Also the motor SHOULD have a reset button make sure that the button is not out and it is fully pushed in
Posted on Feb 19, 2009
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
SOURCE: i have a proform xp 550s treadmill. The belt
change drive belt proform xp 550s treadmill
Posted on Jan 17, 2011
I have a proform 505cst. When I push start, the motor seems to short out. The motor controller LED blinks four times.
Customer Reviews: Proform 505 CST Treadmill (2014 Model)
www.amazon.com/Proform...Treadmill.../B0048HS02...
Amazon.com, Inc.Start here. ..... I was worried it would fall out with the vibration but, as I mentioned earlier, ... The 10% incline and the max speed on this unit more than serves the need ...The sound from the belt and motor is very acceptable (but then its only been .... This morning i was using it for the first time and this treadmill seems great.
Amazon.com : Proform 505 CST Treadmill (2014 Model ...
www.amazon.com > ... > Cardio Training > Treadmills
Amazon.com, Inc.Start here. ..... The ProForm 505 CST Treadmill is designed to get you moving. ....This morning i was using it for the first time and this treadmill seems great. ... I would suggest for anyone that gets this to open up the motor cover and take a look at ...graphics on the instruction manual and figure out what piece went where .
505 CST ' Proform
Jan 11, 2016 | Proform 505CST Treadmill Walking Deck
My Proform 770 EKG treadmill's motor is overheating. What is the voltage that should be pulled during use? Should the walking belt be replaced if we replace the motor?
see the video and lube correctly. 2) go to my personal TIPS for motor help.3) however you must see the voltage in the plate of motor. the tolerance will be +- 10% of voltage. can be voltage continuosly or alternating voltage.God bless you6527db9f-a9f8-47a6-9208-af2b680ea3a0.jpg
Apr 01, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
I have a proform 580 trainer whose speed fluctuates. if it is set to 4 mph it will go down to 3.2 mph then back up to 4 mph and anywhere inbetween those speeds.
1) Tess by RUN the sofware calibration for easy diagnose, troubleshooting and fix it.
2) adjust the speed sensor, test for open or faulty, clean it and tight the plug very well. see the diagram attached.
3) Test the inclination motor for overheating Try to LUBE
4) Lube the deck belt according with the schedule maintenance.
God bless you
Dec 18, 2012 | Proform XP 580 Trainer Treadmill
I have a proform xp 620 treadmill. It started smelling like it was overheating. Today after two miles it just stopped running. What to do?
If you can walk on your treadmill but you get a burning smell from it, you have a bad problem and discontinue use immediately and unplug the treadmill.
Burning smells are most commonly associated with the following problems:
1) Very high belt/deck friction.
2) Short in the motor.
3) Short in the wiring or electronics.
4) Literally cooking the lacquer or cardboard core (on cheap machines) in the motor from belt friction or a drive system
obstruction.
Friction is the #1 cause of this problem. Many cheaper treadmills have a motor with a cardboard core (people wonder why we are so
down on cheap treadmills) and if the voltage and amperage through the motor heats it up sufficiently, it begins to smolder. If this is the
case, you normally have to replace the belt and the motor and inspect the deck. If the armature has cooked enough in the motor, you
also have to replace the motor.
If the belt and deck check out OK, check for a short in the motor. You can run the motor with an independent power source like a fullycharged
cordless drill battery to see if the symptoms are the same. Click on the following link for our motor test.
If the belt and deck check out and the motor is OK, then check your wiring and electronics for signs of scorching and replace the
appropriate part(s).
Sep 09, 2011 | Proform XP Weight Loss 620 Treadmill
My treadmill starts for about 10 seconds and then shuts off. what could be wrong?
If it resets after a few minutes something is causing it to overheat. Have you recently made any adjustments to the walking or motor belt? Too much tension on either will cause strain and overheating.
Jan 15, 2010 | Proform Sport 1000 Folding Treadmill...
I have a proform xp 550s treadmill. The belt
Aug 26, 2009 | Exercise & Fitness
Walking speed for 2 hours and the machine just shut off would't turn back on for 20 minutes why?
The motor has a thermal protection device that will stop the motor if it becomes overheated. Eric
Aug 04, 2009 | Nordic Track /proform Treadmill...
Proform 450 X treadmill powers on, but trips current when started
There could be a combination of problems. I would first start with disconecting the motor leads and see if it trips the breaker. Then elevation motor would be next if no change from disconecting motor. More than likely it's a motor issue.
Jun 06, 2009 | Proform CrossTrainer Treadmill
My proform 830 qt circuit keeps flipping
I've been having this problem too and it seems the best solutions i've came up with have been to buy a lube kit for the treadmill from the proform website or replace the circuit breaker.
Dec 12, 2008 | Exercise & Fitness
Exercise & Fitness Logo
223 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
