Question about 998T Bitwriter Programmer
Where to plug a bitwriter
Where to plug the bitwriter on the alarm in order to read or write to the alarm
What is the esp indicator for on a car amplifier
I found this
when illuminated (yellow) indicates ESP®
functionality and
is used to diagnose ESP®
features. The LED flash characteristics will assists in diagnosing the type of fault (see Appendix).
NOTE: The LED on top of the amplifier may also illuminate and flash with the ESP®
LED
indicator, if this option has been enabled by your installer (requires Bitwriter®
12. ESP®
Port - connection port for Bitwriter®
or ESP2 security system.
I googled it but all i came up was people with a flashing light and mine was solid so i figured id askk!!!! but i think i figured it out i took the sub out and pulled the box terminals and tightened them cause i noticed they were loose and viola it worked.
To further confuse I found this, but don't believe it.
ESP ties the amp into your vehicle's alarm system. If the amplifier is working normally you can ignore the light. Note that this is NOT the protection LED for the amplifier.
Aug 24, 2015 | Cars & Trucks
How do I change battery in alarm system
Find the main box that has the alarm control board in it. This panel can have a 12v 4ah battery or a 12 7ah battery. Unplug the old one, plug in the new one. Make sure you put the black to black red to red it doesn't matter what order but if you do it backwards then you'll have to guy buy some small fuses. GIve it about 12-24 hours and it should clear from the keypad.
Mar 19, 2014 | Honeywell Ademco Alarm 6150rf Keypad Lk
How do you reprogram start duration for a longer time
You do realize that there are multiple remote starter manufacturers and, that these multiple manufacturers have different programming methods. However, the 12 minute run time is a default run time for Directed Electronics (Viper, Python, Clifford, Avital, etc) but, that does not mean that it is a DEI product. If it is a DEI product and you wish to change your runtime to 20 minutes, it can only be done with a BITWRITER. The installer should have this. The runtime settings that are optional without the bitwriter are 12, 24 and, 60 minutes for the more expensive units.
Jan 14, 2013 | Vehicle Parts & Accessories
Where can I get a viper 5501 installation guide
That link there should take you to a pdf install guide, bit i have to warn you first, this guide and the instructions all have one thing in common. That is a warning that your particular system is designed FOR PROFFESSIONAL INSTALLATION ONLY. Meaning if you make an ooopsie, and kill the system, to bad so sad you didn't have a pro install it. But here is the link anyways. Do as you see fit
http://www.google.ca/url?sa=t&rct=j&q=viper%205501%20installation%20guide&source=web&cd=3&ved=0CCwQFjAC&url=http%3A%2F%2Facsdistributors.com%2Fuploads%2Ftechinfo%2Fviper%2Fmanuals%2F5501v%2520Install.pdf&ei=SDD0TsvkBcLAgQeKhMSSAg&usg=AFQjCNG4tG3EDwXjxt6nE-uRy4dWhvFhDA
Dec 22, 2011 | Viper Security and Remote Start System...
I need instructions for my timex clock
Hello
Here are the instructions for your clock-radio.
Installation
1* Remove unit and all packing materials from the carton. You should save packing
materials in case unit needs to be returned for service. If you do not wish to save the
materials, please dispose of them properly.
2* Place the unit on a stable, level surface, close to an AC outlet, out of direct sunlight,
and away from sources of dust, dirt, heat, water, moisture, vibration, or magnetic fields.
3* After installing the batteries (see below) and reading the Maintenance notes, plug the
AC cord into an outlet.
"Sure Alarm" Battery Backup Installation
It is strongly recommended that 2 "AA" batteries be installed into the unit, as directed below,
in order to activate this product's "Sure Alarm" Battery Backup feature. (The model should
come with two batteries already installed.) In the event that the AC power cord is disconnected
or a power failure or other interruption occurs, the "Sure Alarm" Battery Backup will maintain
clock and alarm settings for the life of the battery, ensuring that the alarm (buzzer only) will
sound at the set time. During any interruptions the time and alarm settings will be saved
and automatically restored when AC power is again active.
1* Gently turn the unit over and remove the battery
compartment door.
2. Install 2 "AA" batteries (alkaline is recommended for
longer life), while making sure that the + and - ends
match up with those inside the battery compartment.
3* Slide the battery compartment door back on, making
sure the door locks into place, and gently return the
unit to its upright position.
Aug 19, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
Change VIPER Responder One runtime
You MUST take it to your local professtional installers shop to have that done! It only takes a minute or two.
Dec 12, 2009 | Remote Start System
How to program a remote control for a phyton 1400 xp car alarm and remote starter
open s door turn on the key to the on position press the valet button once and then press one more time and hold it , you will hear a chirp and then you hit the lock button on your remote and then you will hear another chirp. Once you heard that you can let go of the button and turn off the key and your new remote should be program. Now if you have special settings set to the other remotes then you must also program them as well. The only way to program those settings would be using a bitwriter, and only authorize shops have those
Jun 10, 2009 | Vehicle Parts & Accessories
Newly installed 1400xp remotes do not work
I don't know where you live but i would recommend that you either go to best buy or a dealer that sells and install viper alarms and purchase a remote they should have a bitwriter to unlock the remote start brain if indeed it is locked.
Mar 04, 2009 | DEI Python 1400XP Remote Start/Keyless...
GES050 SPACESAVER CD PLAYER/RADIO ALARM
I haven't tried this yet, but I see online that WHILE it is ringing, unplug it for at least 20 secconds, and then plug back in.
Keep your fingers crossed!
Dec 30, 2007 | Audio Players & Recorders
998T Bitwriter Programmer Logo
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
