Question about HP Wireless Optical Mouse
I have a Gateway Laptop and I bought a HP 3-Button wireless mouse
The first time I plugged the USB receiver in, it worked fine, but when I turned the computer off, I disconnected the usb receiver. I cannot get it to reconnect. What can I do?
    Novelist:
  • 126 Answers
As u said that the usb is now not working and it used to work before and what u can try is that try and connect this same usb to some other computer and it works on the other computer that means the prob is with the computer and if it doesnt work then the usb device has gone bad and replace it..but before that just once flash the bios and restart the computer and then what also u can try is that u can dod the system restore...and if none of the usb device works with this computer then definately replace the motherboard.
Posted on Jan 26, 2009
How to install 2.4Ghz wireless mouse with USB receiver?
Insert the batteries into the mouse. Turn the mouse over, find the battery cover, and slide it off. Insert the appropriate batteries-usually two AAs.
  • The wireless receiver that plugs into the computer uses USB power, so it needs no batteries.
Connect the receiver to the computer. If your computer has a USB port (as most do), plug your receiver into an available port. There will also be a green adapter supplied, in the event that your system requires the use of the mouse port. Caution-don't try and force the mouse adapter into the keyboard port!
  • The mouse receiver has a USB plug (left), but can also plug into the mouse plug through the adapter it came with (right). If your receiver plugs into the USB port it should look like the left. If it plugs into the mouse plug it should look like the one on the right, only connected to the receiver.
Connect the mouse to the receiver. Place the mouse in close proximity to the receiver, and note the following:
  • The receiver should have a visible button that is easily pushable by the average human finger.
  • The mouse will usually have a very small reset button in a hole on the bottom that can be pushed by something like a pencil or paper clip.
  • Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
Find a permanent position the receiver. Place the receiver where it won't be far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk.
  • The furthest a wireless mouse can get away from the receiver and still function is about 9 feet (2.7 meters), so keep that in mind.
Test your new mouse.
  • If you plugged into the mouse port, restart your computer.
  • If you plugged it into the USB port you should be able to use it immediately.
  • When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Adjust your mouse settings. Use the control panel that came with your wireless mouse, or download the necessary software from the manufacturer's website. Adjust the settings so that the mouse performs as you require.
Oct 18, 2014 | Computers & Internet
Wireless mouse won't work, have replace battery, rebooted laptop removed and replaced mouse connection etc. Was working fine until yesterday
Is it not working at all or is it moving erratically across the screen? If it doesn't seem to be working at all, turn off your mouse then unplug the receiver's USB cable from the laptop for about 5-10 seconds then plug it in to another USB port. It may detect a new device, just let it do the automatic installation if it asks. You should here a 'tada' or ding sound when it is plugged in. When installation is completed or about 10 seconds after you hear the sound, turn your mouse back on.
If it still doesn't work, try shutting down your laptop completely instead of just rebooting it.
If it still doesn't work after that, make sure you have a spare USB mouse available then uninstall the software for your wireless mouse or mouse/keyboard combo then reinstall it.
Mar 23, 2011 | HP Wireless Optical Mouse
I bought a gateway zx series computer 3 weeks ago. the wireless keyboard and mouse that came with it has stopped working for no apparent reason. the computer says that it doesn't recognize the device. i...
hi Karnarc.
How do I troubleshoot my Gateway wireless keyboard and mouse? How do I troubleshoot my wireless keyboard and mouse?
If you are experiencing issues with your wireless keyboard and mouse not working properly, perform the following steps to troubleshoot the wireless keyboard and mouse.
  1. Make sure the USB connector from the receiver is properly plugged into a USB port on the computer. Some systems ship with the receiver already preinstalled in the unit itself. Please check your mouse to see if there is a receiver inside of the battery compartment door.
  2. Make sure wireless keyboard is not on a metallic surface.
  3. Ensure that the receiver is 8-inches from other electrical devices.
  4. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
  5. Check the batteries in the keyboard and mouse to make sure they are installed correctly.
  6. Test the batteries to ensure that they still have a charge.
  7. Verify the On/Off switch on the keyboard and mouse are switched to On.
  8. Some receivers, keyboards, and mice may have a connect button. If so, follow the steps below:
    1. Plug the USB receiver into a USB port on your computer.
    2. Press the connect button on top of the receiver and the button will blink.
    3. Press the connect button on the bottom of the keyboard to activate the wireless connection.
    4. Press the connect button on top of the receiver and the button will blink.
    5. Press the connect button on the bottom of the mouse to activate the wireless connection.
Dec 03, 2017 | Gateway Computers & Internet
Purchased new laptop and wireless mouse, first day worked great, after a week tried to use mouse again.....just not working have replaced battery no luck
I would try unplugging the usb receiver and restarting the computer.
Then plug it back in.
Sadly, with these, along with replacing the battery, that's the only option.
Mar 12, 2011 | HP Wireless Optical Mouse
Trying to install logitech wireless mouse on Acer laptop with Windows 7 but not seeing the device. Wireless button is on and active on the laptop
Wireless button on laptop has nothing to do with wireless mouse. Plug in your mouse receiver that come with the mouse in to a USB port on your Laptop. Turn on your Mouse and hold the reset or sync button on the bottom of your mouse for a few seconds, so that the receiver can synchronize with your mouse. Mouse should now work OK
Jan 04, 2011 | Logitech Cordless Mouse
I have a Dynex Wireless Optical Mouse (Model No. DX=PWLMSE) and it works when I plug it into my netbook. When I try to use it with my laptop (Gateway), the cursor does not move. I have tried to use the...
On some computers, the mouse will work as soon as it is plugged in, while on others you'll need to manually set the connection. To do this, plug the USB receiver into the computer, then press the Connect button on the receiver. Once the lights start flashing, press the Connect button on the bottom of the mouse. (Make sure the mouse is turned on first.) It should now make the connection.
Hope that helps!
Sep 09, 2010 | Dynex Wireless Optical Mouse
Wireless Mouse on a laptop with built inTouchpad on the keyboard
No need to disable the touchpad they should both work at the same time. Have you tried both the mice on another PC?. The first mouse should have the correct software already installed but you will most probably need to install software for the microsoft mouse. I hope you have tried resetting by hitting the button on the receiver then while its flashing the button on bottom of the mouse? If all this fails do have any other USB devices you can test on laptop?......good luck
PS I hope its not the batteries
Oct 31, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have bought a saitek m80x wireless notebook mouse for my laptop, the man at the shop said it would work on my laptop i have plugged the usb in it said it installed the mouse is on (glowing red...
Cracked it! Instructions and website are useless!
What it does not tell you to do is:-
1. plug in wireless usb part and let windows install.
2. put batteries in mouse, it turns on automatically but turn it off by pressing the button underneath for 3 - 5 seconds.
3. Press the button on the wireless usb stick until the green light on the stick comes on. When you release the button it stays on for about 10 seconds. In the time that the green light is on turn on the mouse with a short press on the button underneath to register with the wireless usb stick.
4. Well it worked with mine after I figured it out - no thanks to the instructions. tried on vista ultra and xp home.
Oct 03, 2009 | Computers & Internet
The USB/wireless mouse does not work on my Dell Inspiron 1525
make sure there are no power cables close to the mouse or receiver, I have seen this cause problems many times.
Also try pressing the connect button on the receiver then keep pressing the connect button on the mouse until the receiver light stops flashing
Jan 25, 2009 | HP Pavilion MX70 17" CRT Monitor
HP 3 button wireless optical mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Oct 04, 2007 | HP Wireless Optical Mouse
HP Wireless Optical Mouse Logo
61 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
