CD player fails to read CDs Sharp CD BA150 3 Disc Rotary Charger System : Issue; CDs that are loaded into the trays do not read/play, even though they did previously. Most disks will spin a little while and then stop and the unit says "No Disk".
    Scholar:
  • 93 Answers
This is a typical problem when the laser " eye" gets dust on it, unplug the unit and you can try to remove cover and spray the optical pickup "eye' with canned compressed air or other type of optical cleaner found at say like radio shacks, I have solved many disc reading errors with this method
Posted on Jan 26, 2009
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
When I load a cd in my Stanton C324 it reads "No
Hello
Clean your CDs before and after playing them. Although the compact disc has a much longer lifespan than does something like a cassette tape, it can be more fragile. Scratches, dust or other damage to the data side of the CD will cause many CD players to fail to read the CD or cause the CD to skip.
Examine the type and format of the compact disc if your CD player fails to read it. Verify that your CD player can read the type of CD and the files contained on it. Just because you've burned a collection of songs to a CD, for example, doesn't mean that your CD player will be able to recognize that information. You must burn CDs in a specially formatted "Audio CD" mode to play them on a CD player, or your CD player must be able to recognize the MP3 file format. Some CD players have limitations on the type of CD they can read. Verify that your CD player can read CD-R, CD+R, CD-RW or CD+RW compact discs.
Update your CD player's driver, if your CD player is a drive connected to your computer. Click "Start" and select "Control Panel." Click on "Hardware and Sound" and select "Device Manager" under "Devices and Printers." Right-click the icon for your CD drive and select "Update driver software." This may solve any issues the drive was having with playing CDs.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Stanton C324 Mp3 Cd Player With Effects...
Doesn't read the cd. says
If any cd player does not play, three things, it either the wrong format, dirty cd or faulty cd player. If your cd player play others cd, it mean others are the wrong format. for example older cd player is not compatible to play some of the cd formatted from the computer. if the cd player does not play anything that mean the cd player is faulty.
Aug 27, 2009 | Sony Audio Players & Recorders
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Cd player will not read disc
Unit probably has defective disk motor or function sensor
Apr 25, 2008 | Audio Players & Recorders
CD Player returns NO DISK code
looks like the OPTICAL LEN part D.O.A. on you , I suggest to replace the OP LEN , AND SHOULD BE ABLE TO PLAY. hope this helps
Apr 19, 2008 | Sharp CD-BA150 Shelf System
Cd cleaning disc is not advisable to clean your laser lens.. all you have to do is manually cleaning method! open the unit go to laser lens and clean it with 100% cotton buds then rub it slightly clockwise, but careful this is sensitive parts.
Sep 26, 2007 | Sharp XL-MP130 CD Shelf System
129 people viewed this question
 Grubhead
Grubhead
