Question about Xerox Staples XRX-LM1910 Laminating Machine
MACHINE TURNED OFF
WHAT DO I DO
Top load, direct drive type,started machine while water supply was turned off, how do I clean the setting to restart machine. it's still in last setting with no water in tub
Unplug machine, wait 10 minutes. Make sure water supply is turned on. Then plug machine back in. It should be reset and ready to run.
Jan 20, 2018 | Washing Machines
ASCO Washing Machine - AEA 12001
This is normal on most machine. Once the machine finished washing or you switch off the maching manally, you will have to wait for around 2 to 3 mins for the mechanisim to unlock the door.
Apr 07, 2014 | Asko Washing Machines
My brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
Jul 13, 2012 | Brother Sewing Machines
While winding the bobbin my machine stopped threading and all the lights on the front started flashing. I turned off the machine and turned it back on and it did the same thing.
Turn the machine back on, slide the bobbin winder all the way over to the left, and push the reverse sewing button 3 times. That should reset the machine.
Sep 25, 2010 | Singer 7462 Mechanical Sewing Machine
When i go to clean the infuser it will not come out
Have you turned your machine off? You can not remove the infuser if the machine is still turned on, and if you try you will probably damage your machine.
Jul 28, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
Xerox Staples XRX-LM1910 Laminating Machine Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
