Is Model Philips/Magnavox VRA631AT22 HDTV Ready
Hi, I have my rabbit antenna hooked to this VCR which is then hooked to my Olevia TV (Model: 332-B11). It is currently an analog antenna. I am not sure if both these models are ready to accept HD signals. The TV indicates HD Ready but I am not able to hook my antenna directly to my TV as it does not have slot for me to hook into. It only allows to plug in the 3 cables (Red, Yellow, White) which is hooked to my VCR which does have a slot for me to hook up my antenna to it.
I am not able to tell if there is a Digital Tuner built in to my TV.
Appreciate your advice.
Thanks, Shatish
    Problem Solver:
  • 4 Answers
I am not absolutely positive, but I do not think you will be able to get ANY TV after the transition without a converter box, unless you hook up to cable or a dish. IF your Tv were able to get HD, it would say so on the set...
I live w/ a son & DIL and we have Direct TV so we can already get HD programs, but since none of our sets are High DEF we do not get them IN high Def.... I also have two small TVs,- one in the spare bedroom and one in my computer/ library... both of those are hooked up with old fashioned antannae..[ I also have a VCR hooked up to each]. I have added a converter box to each and can already get more stations than I did before and the picture is better,
although it is NOT in High Definition; You have to have a High Definition TV to get programs in that foremat, although you can get a GOOD program; so it was worth the small amount I paid for the boxes... I got the Government discount coupons so they were reasonable...
Last week one of the local 'Best Buy' stores advertised the converter boxes for as low as $9.99 w/ the coupon... I think the Gov'mt has run out of funds, however.
I hope this answers your question...
Posted on Jan 25, 2009
Are there any firmware updates for the olevia 332-B11
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 22, 2014 | Televison & Video
How do connect antenna lead to a olevia 332-b11 set??
Either via the cable fitting or via the av jacks from a box.
Mar 14, 2012 | Olevia 332V LCD TV
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Dec 17, 2009 | Olevia 332V LCD TV
How can I get the firmware update for Olevia 32 in. 332-B11
you need the firmware flasher and the usb driver, I have both from a long time ago
Oct 16, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
How do L set up the converter with a TV , a vcr and "Dish" satte
It sounds like you need a three way splitter.
You need to reverse the connections; the splitter has input and out. Hook exterior antenna, converter box, and satellite to the three side terminals (out). Hook the single sided terminal to VCR input. Connect the VCR out to the TV input. This configuration assumes that you will be using the VCR to record from all inputs. The TV has to be set to channel 3 to act as a monitor for your other devices.
Hope this solves your dilemma.
Feb 22, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a vcr/dvd hooked up to my present tv with a antanna. How do i hook up the digital converter. so thatI still could use vcr. Thank You
It depends on brand of converter. In Radioshack they have one with AV-in ports (for $56 (-$40 coupon = $16). So TV signal going trough antenna and DVD/VCR going trough AV-in of converter to the same antenna of TV. Or you will have to hook up the CONVERTER - ANTENNA IN VCR/DVD - Antenna OUT VCR/DVD - ANTENNA IN TV. And you will use the remote of converter to switch the channels.
Good Luck
Jan 10, 2009 | Philips Magnavox DVD/VCR Dual Player
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Converter box
The cable that goes into the TV sould come from the VCR output to TV plug.
The antenna input to the VCR should come from the antenna or DTV converter box.
The signal passes through or loops through the VCR.
If you hve a manual the connections are on pages 14 an 15.
Let me know if there are any problems and a time you might be hooking this up.
You can download a manual here:
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Oct 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
