Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Trying to find the Thermal Reed Switch
I know the Thermal Reed Switch ( made by Tokin pt# TRS5-60BLRU) is bad. Where can get it? I checked with Tokin and it seems like they are part of NEC. However they only sell the part to big distributors. Anyone know of any distributors that will sell me just one?
Get the board location number and I can get you a Mitsubishi part number and the part can be bought from Mitsubishi.
Posted on Jul 14, 2007
SOURCE:
I keep getting a speed error message when I start the belt
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
Precor Error Code LS
Dec 08, 2014 | Precor Exercise & Fitness
Error code LS
Corrective Action
Mar 26, 2014 | Precor Exercise & Fitness
Precor L5 error
Corrective Action
Dec 19, 2013 | Precor C954i Commercial Treadmill
Precor treadmill error L5
Corrective Action
Feb 25, 2012 | Precor 935 Premium Series Treadmill
Console getting erratic numbers and motor will not run. i have checked the reed. my father does not remember how tech support had told him to reset console. Was working intermittenly before we checked...
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
fINALLY: Test the Optical Sensor if have it
http://www.youtube.com/watch?v=E-q-uS4t6so
Aug 21, 2011 | Nordic Track NordicTrack Treadmill, A2550
I have a CardioZone Commercial CG3 - 500. After 2-3 seconds of use the screen shows ERR 3. How do I fix? I tried turning off for a few minutes and re-trying but same problem. Thank you for you help!
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 12_3_2011_4_59_31_pm.gif2nd Step: tight the keypanel vs Display board and clean with contact cleaner spray . Tight the connector from Display Board vs Main Motor Board.
See the block diagram how the main motor board has aprox 90% functions in any treadmill. Good luck, Now you will strong resultant in determine what is faulty.
Aug 18, 2011 | Cardiozone Supersport Hr Club Commercial...
I have a toshiba laptop worked fine until yesterday, I turn it on I can hear the drive turning, and all the lights are on, but the screen is black. I tried to hook up an external monitor still no video. ...
Try to change this part on your motherboard :
http://cgi.ebay.com/NEC-Tokin-OE128-High-Speed-Decoupling-Device-Proadlizer-/220797295383?pt=Motherboards&hash=item33688b5b17
Thanks
Jun 27, 2011 | Computers & Internet
Hot Cooktop indicator
You either have a reed or thermal limiter switch that is bad or a switch that is bad. The only way to determine it is with a meter. I think that this job is better left to a professional unless you know how to use a volt/ohm meter.
Apr 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Overheat led blinking
Did you ever get a answer to this question? I have a hitachi 50vs810 with the same problem. I found the same sensor "tokin ohd3-90m."
I ohmed across mine and it shows open. I then held my lighter under it and it stayed open. I suspect this part is bad so I tried jumping it out. No change. Still have the same blinking temp light.
So... in the end I don't know if I tested it right or not either. Good luck and let me know if you learned anything that can help me out.
Apr 09, 2008 | Hitachi 50VS810 50" Rear Projection HDTV
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
