Question about Samsung LN-S4051D 40 in. LCD Television
Green Pixel or dots issue on Samsung LN-4051D
I thought it was a heat issue but its now winter and its happened again. I have green dots or pixels on black or white colors and it seems to just surround lines. Now that i'm looking at it, i'm getting red dots now too. *sigh*
It happens on DVD's, cable, PS3, while watching stuff on my media center PC. So its not any single component, its definitely the TV.
What do i need to replace to get this working again?
  • Anonymous Feb 18, 2009
    Would that be the same for some one seeing red dots instead of green? BTW- symptom comes and goes periodically.
  • 335 Answers
That's a flaw in the driver/timing circuits, but it could also be something simple like a ruptured ribbon cable or poor connection during manufacturing. Simple or not either way the driver/timing circuits need to be serviced by a professional technician.
Posted on Jan 29, 2009
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
The model is Samsung LN-T4661F. It power cycles at least 3 times every time I turn it on. Once the screen comes on there are, most times, pink pixels randomly all over the screen. I have to turn it off...
good day .maybe theres a defect in the board causing the screen changes abnormally. maybe the screen module is defective. just consult that problem to samsung service center to fix your problem.
Jun 24, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Why got green dots / image seen on screen?
Those green dots are dead or "tired" pixels. The only thing you can try to fix this, is doing a pixel massage. Grab a pen and put some sort of towel over it and make a circling move over the pixel.
If it won't work the only thing you can do is get used to it that you have a dead pixel. ( i also have one. Very annoing)
May 21, 2010 | Philips 42FD9932 42 in. Plasma Television
Horizontal green bar on plasma tv, please help!
what it is, is on plasma screen tv's and LCD, they can get too cold, too hot, or over-powered. when any of this happens with just the right conditions, a thing called "dead-pixel" occurs. basically, the pixel will not respond any longer to tbhe electrical signal, so will not change with the rest of the screen. its basically broken
Sep 14, 2009 | Samsung LN-T4665F 46 in. LCD Television
I have a green dot on my screen of my JVC HD52G887
Hello. If it resembles a tiny bright green dot, this is most probably a dead pixel. In the troubleshooting guide in the user manual, the manufacturer states that some pixel loss is normal--either they will be gone or permanently "on". If the unit is new(i.e. still under some warranty) talk with the supplier about options--they *may* decide to replace it if the dot is in a particularly annoying location. Be aware though, they won't be under obligation to do so. I own a LCD projector with a few visible pixels--as devices such as these(lcd tv's, projectors, plasma, etc.) age, this type of phenomenon is going to occur. Normally--and this certainly isn't always true, there is a tolerance of 3-9 pixels. Check with the supplier and/or manufacturer for individual specs. Especially if the unit is under warranty!--Hope I successfully assisted you.---Rick
Jun 24, 2009 | JVC TS-CL110UAA Projector Lamp
Samsung LNS 4051D color problems
1.T-con board or related cables problem -- 60%
2.replace Main Board -- 40%
Jan 25, 2009 | Samsung LN-S4051D 40 in. LCD Television
Green noise on all black images on my SAMSUNG LN LCD TV screen
I had a similar problem with my LG plasma. I used the Image Sticking Minimization
(Pixel Orbitor, White Wash, and Inversion) feature which is designed to prevent image burn in and ghosting. This ISM feature may be available on the Samsung or any other brand under a different name. I activated the "white wash" option for about 30 mins, the screen turns white and somehow the pixels get reset. The green noise disappeared after that.
I hope this helps. Phezbuster
Dec 20, 2008 | Televison & Video
Pioneer Elite 1130HD
DAVE-UNFORTUNATELY ONE PIXEL IS STUCK ON AND TO FIX THAT PROBLEM WOULD MEAN REPLACING THE WHOLE PLASMA PANEL ITSELF.JOE TV
Nov 06, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Green and Blue spots on screen
Sounds like stuck pixels, you really can't fix that. Do some google research if you are curious what a stuck pixel is.
Oct 30, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Ultrazoom pixellation problems
No, it isn't to do with white balance. Instead it is due to a combination of noise swamping (or at least modifying significantly) the exposure measured by the pixel, and the interpolation algorithm in the sensor processing chips that "guesses" the colour of a pixel based on the readings from nearby pixels. These algorithms are better at rendering certain kinds of image elements than others. Large areas of darkish colour often fool the algorithms into attempting to produce detail that doesn't exist.
Sep 13, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Samsung LN-S4051D 40 in. LCD Television Logo
475 people viewed this question
Henry  Thomas
Henry Thomas
