Question about HP Photosmart 2575 All-In-One InkJet Printer
How test print hp photosmart 7525
Changed cartridges, no offer to print test as with original install - want to align cartridges
leroyal
  • 2120 Answers
SOURCE: Printer Alignment Failed in HP C5280
You must replace both with new GENUINE HP ink cartridges at the same time or alignment will fail.
This is how HP makes their money.
Posted on Jan 18, 2009
smwsolutions
  • 73 Answers
SOURCE: printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Posted on Jul 19, 2009
buffalonyman
  • 1865 Answers
SOURCE: HP Photosmart 3310 All in One - just failed
Go to the following link to get support for your printer
http://h10025.www1.hp.com/ewfrf/wc/product?product=439491&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Nov 05, 2009
Testimonial: "Straightforward answer & appropriate link!"
sgoswami
  • 114 Answers
SOURCE: HP 6000 Won't print with yellow cartridge
Try this :
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Regards
Soumajit
Posted on Mar 12, 2010
mediastormer
  • 135 Answers
SOURCE: I am setting up a
Step one: Load the correct type of paper Remove all the paper from the tray. NOTE: Colored, photo, or used paper can cause the alignment to fail. Load unused, plain white, letter, or A4-sized paper with a brightness level of at least 85 into the tray. NOTE: Look for the brightness level on the paper packaging. Step two: Align the All-in-One Press Setup . Press 5 . The product opens the Tools menu on the control panel display. Press 3 to select Align Printer . The product calibrates, aligns the printhead, and then prints an alignment page. Recycle or discard the alignment page. Video of aligning the All-in-One The following video demonstrates the steps for fixing a carriage or paper jam. The product shown in the video is the HP Photosmart C7280. The outside of the product might look different, but the steps are similar for the same for the HP Photosmart 3100, 3200, and 3300 All-in-One series products. If you have trouble viewing the video or to view the video in a different size, click here to play the video (in English) on YouTube. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step three: Clean and reinstall the cartridges If the contacts on a cartridge are dirty or do not seat correctly, the alignment might fail. Follow these steps in the order presented to clean and reinstall the cartridges. Gather the following materials: Soft, lint-free materials, such as foam-tipped swabs, that do not stick to the electrical contacts Clean, lint-free paper to rest the cartridges on (coffee filters work well) Distilled water Press the Power button to turn on the product. Open the cartridge door. Squeeze the tab below the black cartridge on the far left side of the carriage, and then lift the cartridge latch. 1 - Cartridge latch for the black cartridge 2 - Cartridge latches for the color cartridges Remove the cartridge by pulling it toward you and out of its slot. CAUTION: Do not remove multiple cartridges at the same time. Remove, clean, and then reinstall each cartridge one at a time. Do not leave a cartridge outside the HP All-in-One for more than 30 minutes. Inspect the cartridge contacts for ink and debris buildup. Dip a clean foam rubber swab or lint-free cloth into distilled water, and then squeeze any excess water from it. NOTE: Hold the cartridge by its handle. Do not touch the copper-colored contacts with your hands or anything other than a foam rubber swab or lint-free cloth. Clean only the copper-colored contacts. 1 - Copper-colored contacts Slide the cartridge back into the empty slot. Secure the cartridge in the slot by pressing down on the latch until it clicks into place. Repeat steps 2 through 5 for each of the cartridges. Close the cartridge door, and then try to align the product again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step four: Check the ink levels Empty or nearly empty cartridges can result in alignment failures. Follow these steps in the order presented to check the ink levels in the cartridges. Press Setup Press 5 , and then press 1 . The Tools menu displays. Click Display Ink Gauge . The gauges for the six cartridges display. Check the gauge for empty or almost empty cartridges, and then replace any you find. The product automatically performs an alignment and prints an alignment page. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step five: Replace the cartridges Follow these steps to replace any cartridges that are empty or low on ink. Open the cartridge door. Squeeze the tab below the black cartridge on the far left side of the carriage, and then lift the cartridge latch.
1 - Cartridge latch for the black cartridge 2 - Cartridge latches for the color cartridges Remove the cartridge by pulling it toward you and out of its slot. CAUTION: Do not replace multiple cartridges at the same time. Replace each cartridge one at a time. Do not leave a cartridge outside the HP All-in-One for more than 30 minutes. Remove the new cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot. Slide the new cartridge forward into the empty slot. Repeat 2 through 5 for each of the cartridges. Close the cartridge door, and then try to align the product again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step six: Reset and relocate the product A power reset drains power from the product and returns the product to the same settings after restarting. Moving the product to another location and plugging it directly into a wall outlet can eliminate any potential power deficiencies that might prevent a successful alignment. Make sure that you have the product turned on. If necessary, press the Power button to turn on the product. With the product turned on, disconnect the power cord from the back of the product. Relocate the All-in-One to a different power outlet, preferably in a separate room Plug the power cord directly into the wall outlet. Do not use a power strip. Reconnect the power cord to the back of the product. Press the Power button to turn on the product. Load plain white paper into the tray. Try the alignment again.
Posted on Oct 30, 2010
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
Photosmart d5160 keeps printing a test page after i print anything
Please perform the following steps:
* Make sure the CD/DVD tray is closed.
* Double-click the HP Solution Center icon.
* In the HP Solution Center (for Windows OS, if you are using Mac please let me know), click the tab for the HP Photosmart 5100 series.
* Click the Settings button.
* Point to Print Settings.
* Highlight and click Printer Toolbox.
* After the Printer Toolbox opens, click the Align print cartridges button.
* Follow the on-screen prompts to align the cartridges and print an alignment page.
:) Dr Tony
Apr 17, 2010 | HP Photosmart D5160 InkJet Printer
Jan 18, 2009 | HP Photosmart C5280 Printer
I have a Photosmart C5280 Have changed colour cartridge for the first time Alignment has failed twice Book tells me to contact you Print cartridge alignment failed.
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
then try to print if the alignment fails then you need to change the cart in the
printer if its original hp new cart then get replaced .....
Good luck..
Jan 06, 2009 | HP Photosmart C5280 InkJet Printer
This printer is saying that print cartridges missing, they are both brand new. HP Photosmart C4280 all in one. what to do.
Be sure to run the print test page after installing cartridges.  After doing so, place the page face down on the scanner and select cartridge alignment.
gary.schaut@gmail.com
Jan 06, 2009 | HP Photosmart C4280 Aio Printer
Keeps doing print alignment
Re install the printer using the original disc. This should then reset the printer to its ariginal default. This problem should not happen, only if you have made changes since the original instalation. If this still happens, download an up todate driver.
Sep 11, 2008 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart 2575 All-In-One InkJet Printer Logo
223 people viewed this question
Seeker5211
Seeker5211
