Question about Amana ASD2620HRW
Icemaker not making ice
Reefer making crackling sound
  • ranter63 Jan 25, 2009
    do i need to defrost the reefer and freezer
    Master:
  • 416 Answers
It looks like it produce to much of freeze that is why you can hear cracking sound due to contraction or expansion of walls inside tha fridge. Water line probably frosen. Unplug it for 12-20 hours.
It will remove ice and water from pipes
Good Luck
Posted on Jan 25, 2009
    Genius:
  • 3,422 Answers
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    Brigadier General:
  • 8,619 Answers
Hi
Kindly check it could be because of following reasons :
  • Freezer may not be cold enough.
    Temperature must be 5 degrees (Fahrenheit) or colder to work properly.
  • Normal ice making capacity.
    The ice maker will produce between 2.5 to 4.0 pounds of ice a day depending on your model. Side-by-side models come with a large ice bucket and it may take up to three days to fill this container.
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
    Please feel free to contact for further assistance
    Thanks
    Rylee
  • Posted on Jan 25, 2009
    • Rylee Smith
      Rylee Smith Jan 25, 2009
      You can also try defrosting as it will work for sure
      Brigadier General:
    • 5,158 Answers
    Check that the water lines are not plugged ... could be frozen up
    which would require a defrost
    Robert
    Refrigerators Logo
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
