Question about GE Energy Star WCVH6260F Front Load Washer
Will not spin on any cycle but sounds as if it is running.
This happens now and then, by the time I get someone to come take a look at it a day or two later the problem usually goes away. But when I need it the most, usually on weekends I sometimes have to go to a laundromat because my clothes sit inside the washer sopping wet without get washed. The door remains locked too. I noticed this time it happened when I stopped the cycle midway to add some more clothes. But now I keep trying to restart and the same problem resumes. No spinning just the sound of the machine going.
You have a bad computer board. Its gonna cost about $300 bucks to fix. I had the same problem and guy came, told me what was wrong and had a computer board in his truck replaced it in about 15 minutes and wacked me with $300 dollar bill. It works fine now. the kicker is the stupid washer was 13 months old, 1 month past warranty.
Hope this helps.
Posted on Feb 08, 2009
  • auntperkysgo
    auntperkysgo Jul 15, 2013
    I have told the Geek Squad this for a year. There are cycles that have not worked for that enitre year. Other parts are replaced, but the computer board still remains. I am told to just deal with it.. if I wanted to just DEAL with it I never would have bought the extended warranty!
Agitator running from first of cycle and water running in at end of spin
i have the same problem the hot & cold water is also a load senser switch part # w10248240 the load sensor is built into this switchfind a video on youtube how to open your top panel to the control knob switches you will see the switch #w10248240 there will be a hose to it make sure you can blow thru the hose if clear close the lid unplug the two plugs going to the switch pull the on button to start the cycle if nothing happens its the load switch if it agitates its the timer mine was the load switch one appliance man told me he had both parts go bad at the same time but like i said mine was the load switch took me all day of online serching to get the problem fixed but i found the answers on this site part i found at amazon 50.00 dollers its finaly fixed
Dec 07, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Making a noise during the spin cycle
Hello, it sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves.
Thanks
May 19, 2010 | Washing Machines
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
My Asko W620 washer won't spin the first time through.
Try Googling (asko)(W620)(manual) without parens.
Jul 22, 2017 | Asko W620
My Washer does not spin or agitate when washing, but it spins when drying on cycle...
Hi Mate,
Check the controller, is it digital or analogue ( pushbutton or control knob that turns ) Sounds like part of the switching cycle has burnt out replacement of controler may be the answer
Stoker
May 11, 2008 | Frigidaire GLWS1233A Top Load Washer
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
GE WWSE5200BWW Topload Problem
sounds like the motor needs replaced pretty common on this unit..
May 28, 2007 | GE WWSE5200B Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
