Question about Acer TravelMate 4740
Not able to enable my wifi suddenly.the on off button is not highlighted nor i am able to use it
Not able to switch on my wifi as the buttons are not highlighted.blootooth is working fine as the buttons for it is highlighted.
  • Acer Master
  • 7,627 Answers
In the Tray Notificatin Area, right click the network adapter, open Network and Sharing Center, open Change Adapter Settings, right click on Wireless Adapter, Enable.
Posted on Jan 18, 2013
3 Suggested Answers
ckuzkuz
  • 255 Answers
SOURCE: wifi button not working
I would start with reinstalling your driver for the WIFI:
Acer Drivers
I think it should help you with your problem, although the WiFi works okay
Posted on Nov 05, 2009
Testimonial: "uninstalled the wifi driver in device manager, rebooted my system and it works thanks for the fast answer"
  • 67 Answers
SOURCE: acer 4720,when switched on wifi button,the light
For Windows Based Computers
If the drivers for the wireless adapter contain a setting to toggle wireless radio, it can be located using the
following path: Start > Settings > Control Panel > Right click Wireless Network Connection Icon > Properties >
Configure > Advanced tab
Here you will find a textbox with a list of selectable properties that are populated by the device driver. Once you
select a property there will be a value field with a dropdown box containing configuration options that apply to that
specific property. The name of the wireless radio property may vary because the listed properties are dependent on
each specific device driver. It should be fairly intuitive to determine the correct property if you simply have the user
read all the listed properties to you.
Many laptop manufacturers will place a physical switch on the outside casing of the laptop, so that the user can
easily toggle wireless radio. Sometimes these switches get accidentally turned off, or intentionally turned off and the
end user forgets to switch it back. The best practice in these situations is to ask the user to look for a physical switch
on the case of the laptop, possibly with a symbol of a radio tower next to it. After turning the wireless switch on, the
user will probably need to refresh their network list.
Laptops built by certain manufacturers may have a specific keystroke set up to toggle wireless radio.
Below are some examples of wireless radio software and hardware toggles that we have been able to
document:
Acer (General) - FN,F5
ASUS (General) -The F5R has a toggle switch to turn on and off the WIFI; it is located on the left side of the
notebook
Dell (General) - FN,F2 or FN,F8 or FN,F12
Dell d630 (D6xx?) latitude: toggle switch on the left side towards the front by the PCMCIA slots and headphone
jack
E-machine (General) - FN,F2
Fujitsu (General) - FN,F10
HP/Compaq (General Older models) - Button on upper left on keyboard deck
HP/Compaq (General Newer models) - Button on lower left below keyboard
IBM thinkpad (General) - Most have software switch or button on left hand side.
IBM thinkpad (model not further identified) with wireless switch on front edge of case.
Sony Vaio (General) - switch on front left
Toshiba (General) - FN,F5 or FN,F8 or switch
Toshiba Satelite has a physycal switch on front of case. FN+F8 shows wether wireless communications is
enabled or disabled.
For MAC/Apple Based Computers
MAC OS X 10.4.x (Tiger & Earlier)
Open MAc Hard Drive > Applications > Utilities folder > Set the Configure pull-down to Airport.
Make sure the "Airport Power:" says On. (This is the status or your Mac's Airport card.)
If not, click "Turn Airport On" button.
MAC OS X 10.5.x (Leopard)
Click on the: Apple Icon > System Preferences > Network > Airport > Airport Power - On/Off
Posted on Jan 20, 2010
My digihome wifi sayin disabled I can't go down or use button to enable it is there another way?
Hello Shannon,
Disabled WIFI can be frustrating. In a case like this, there is usually a button on your wireless router or laptop that DISABLES/ENABLES the wifi functionality. I would look for this switch or button and make sure it is ON. On a laptop, it may also be a FUNCTION key at the top of the keyboard. Just hold down the FN key and press the FUNCTION key that has a wireless symbol painted on it.
Otherwise, check the software on your device. Many wifi devices come with software that can be installed from a CD or the Internet. That software may also have a feature that can disable the WIFI.
Apr 29, 2016 | Computers & Internet
How do I connect my Wifi device?
Please add the detail of what the device is, the make and model, the operating system .
If you are talking about connecting a laptop to a network check that the wifi icon in the system tray is present. If it is hover your mouse above it and click in order to make it display available networks. Highlight the network you wish to connect to and click on the connect button.
It may be that your wifi card is not enabled, different machines have different procedures for enabling disabled wifi cards.
If you need this information can you please provide the requested information and resubmit the query
Jun 19, 2015 | Computers & Internet
How can i activate my mouse sensor???
depending on your laptop this will vary
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option.
Click on it and you will see the option to enable your device, then click OK
or
Right-click on a blank spot on your desktop. Scroll down, select "Personalize" and then choose "Mouse Pointer."
Click the "Device Settings" tab. Highlight your TouchPad in the "Devices" section. Hit the "Enable" button.
Click the "Apply" button and then click the "OK" button.
or
Click the "Start" button in the lower-left corner of your computer.
Type "mouse" in the field above the button. Click "Mouse" in the list of items that appear.
Click the "Device Settings" tab. Highlight the touchpad item in the "Devices" list.
Click the "Enable" button. Click the "Apply" button and then the "OK" button.
hope this helps
Sep 24, 2012 | Acer Aspire 5102WLMi PC Notebook
How do you turn on the WiFi feature?
Pressing the keys Fn + F1 at the same time will enable or disable the built in wifi.
Mar 02, 2011 | Coby PC Netbook 1ea
Where is the wifi switch on the ibm thinkpad and how do i fix it
hello dear first you check in the computer BIOS may be disable /enabled so if disable then you enable then its working
if have a button on keyboad then push the button of FN or that key who have a sign of wifi press it
okyyyyy dear by take care
Dec 25, 2010 | IBM ThinkPad T42 Notebook
How to activate wifi in janab
There will one of two different types of switches or buttons to enable the wireless networking feature on your notebook.
Button on the front of the notebook:
  1. Locate the wireless networking button on the front of the notebook.
  2. Press the button to either enable or dislable the wireless networking
  3. Once the wireless networking feature is enabled the button will light up amber.
Switch on the front of the notebook:
  2. Slide the switch to the right to enable or disable the wireless networking feature
    Note: The switch will reset back to the left after switched to the right. This is normal and does not indicate the the wireless feature has been disabled.
Nov 30, 2010 | Acer Aspire 4720 Notebook
Wifi button not working
It is better to give your lap nearest service center..they will help you to solve this problem.
Nov 05, 2009 | Acer Aspire 7720-6844 Notebook
Toshiba satellite wifi not working
Hello
You might have physically switched on the adapter, but in Windows it is still disabled.
In Windows XP, click the start button, look for CONNECT TO (don't go in the all programs menu), and click SHOW all connections. A window opens showing all the connections available. If the wireless connection icon displays a red X crossing it, it is disabled.
To reenable it,
Point the mouse cursor to the wireless connection and right click mouse button. Click enable or repair.
One question though. If your computer is toshiba, you must have installed the configFree software that came with it.
If so, look to the left right of the task bar and click the ConfigFree Icon. Choose Connectivity doctor. It will diagnose your connections. If one is disabled or has a problem, a yellow triangle with an exclamation mark ! will appear on the connection.
Use the device setting thumbnail, select your WIFI adapter . A button at the right bottom side, will show either Enable (if your adapter is disabled), or disable i(f adapter is enabled). With that button, you can toggle between enable and disable. After that click the close button, and hopefully you will be able to surf the web.
Hope it helps
Hope it helps
Aug 21, 2009 | Dell Inspiron 6400 Notebook
Area wireless connections will not appear
press the buttom to the right of the touch pad to enable the wifi card. this button control the card manually
Jan 27, 2009 | Acer Aspire 5000 Notebook
Swann pro 4000 dvr
Press the “Menu” button and use the Up or Downbutton until “Motion” is highlighted then press the “Enter” button. Use the Up or Down button to highlight the “OFF” next to “MOTION RECORD” and press the + or -button until “ON” is shown. Use theUp or Down button to Highlight the (MENU) then camera you wish to enable, then use the Left or Right button to highlight the “OFF” next to that camera and press the + and - keys to adjust the setting to “ON”. Use the Right key to highlight “AREA” next to the camera you wish to enable, and press the “Enter” button. Press the - button to turn on Motion Detection for the whole screen as shown by a green overlay, then do the same for your other active cameras.
Jan 14, 2009 | Swann Communications DVR4-Pro-Net...
Acer TravelMate 4740 Logo
190 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
