Question about John Deere Garden
L110 clutch/brake safety switch where located
3 Suggested Answers
  • 138 Answers
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Posted on Aug 17, 2009
  • 41 Answers
SOURCE: Put on a new clutch safety switch today, same
check the seat saftey sensor,,,sounds like its running because it thinks its brake is set.if your out of the seat it quits unless the brake is set.it will be under the seat.let us know either way we can figure it out..
Posted on Apr 14, 2010
When I engage the blades on my castelgarden XDC140HD ride on mower nothing happens
Unplug the wire at the clutch and check for voltage when the switch is turned on. if voltage is present replace clutch. If no voltage is present replace switch. Make sure brake is released to avoid safety over ride to blade clutch circuit. Check the brake safety switch too. It is normally closed until brake is depressed
May 18, 2017 | Cars & Trucks
Where is the break safety switch located in a 2009 Ford Fusion
Jeanette, break switch is above brake pedal arm, safety neutral switch is on transmission, clutch pedal safety switch above clutch pedal arm. Links below have pics.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
06 ford fusion brake light switch replace
How To Test and Replace the Neutral Safety Swtich Inhibitor Switch P0705
Clutch switch behind clutch pedal Ford Focus Forum Ford Focus ST Forum...
Replace master cylinder clutch Ford Focus Forum Ford Focus ST Forum Ford...
Feb 15, 2016 | 2009 Ford Fusion
Where is the safety switch for clutch on yard machine 16.5
under the tractor on the clutch peddle side the arm there is a ether a gray or black switch there is also a switch under the seat that goes bad that will also cause a no start state its for if you fall off the tractor it will shut down usually it is a good idea to replace these of it is a few years old. if you are talking about the clutch for the mower deck then it will be behind the battery at the back of the dash board. there is a shaft with a tang that activates the switch if you have a electric clutch then check your seat switch and brake switch as well there is a switch usually located by the transmission this is the neutral safety switch. all together they work in a series another words you have to be in neutral with the brake applied and the mower deck in the off position before the the tractor will crank and run. hope this helps.
Sep 02, 2014 | Yard Machines 13AN775S000 500cc 16.5 HP...
John Deere L110 riding mower automatic won't start
have you checked the micro switch under the seat
May 31, 2013 | Garden
John Deere L110 won't start.
check the solenoid on the bottom of the carb see if there is power if no power check the safety switch on the brake/clutch if there is power remove the solenoid and put power and ground to it to see if it opens if not try and clean it with carb cleaner if that works and opens remove the bowl from the carb and check the needle valve on the float make sure it moves
Sep 01, 2012 | John Deere Garden
Where is the clutch safety switch located in a car and what is it connected to?Where is the clutch safety switch located in a car and what is it connected to?Where is the clutch safety switch located in a...
The clutch start switch in a Camry is normally on the floorboard in front of the clutch pedal lever. It can sometimes be mounted on the clutch lever pivot point.
It is connected into the starter motor circuit, as shown here
http://www.turboninjas.com/camry/
in documents st.pdf and cl.pdf
Dec 07, 2011 | 1998 Toyota Camry
Engine will not start john deere L110 garden tractor. have checked batterie OK, have cleaned all connectors for good contact. when I turn start key, there is nothing. although in the light position the...
check the manual again for all of the safety microswitches
one for the seat , one for the brake , one for the clutch mat least
means that you have to be in the seat , foot on the brake and clutch before the starter will engage
Sep 13, 2017 | John Deere Garden
Where is the part located that shuts the mower off when you release the clutch
There is a safety switch for the brake clutch and if the seat safety switch is not activated by someone sitting on it, then the mower will die. So if you are sitting in the seat and the brake clutch is released and the seat safety is faulty then the engine dies, so the seat safety is where you should start looking.
Aug 31, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Replace switches & clutch. When brake is release everything dies. Ineed a wiring diagram.
There are a few safety switches on a riding mower. One is the brake clutch, which must be engaged to start mower if not in neutral for a manual transaxle. Another is a blade engaged safety that will not allow you to start it with the blades engaged and the other is the seat safety that prevents starting if the brake is not engaged.
If the seat safety switch is messed up and you release the brake it will kill the engine. I would start there.
I hope this helps get you going.
Aug 03, 2011 | Garden
MTD riding lawn mower will not start. Know for sure not the engine or the battery. When the clutch is depressed and ignition switch is turned no sound, nothing. Could the problem be in the Clutch Safety...
Hello:
>>From your Description it Sounds like the Clutch/Brake Switch Bracket has Bent and the Safety Switch is Not being Moved enough to Activate this Switch.
>>The Following is an Instruction File for the Safety Switch System. Any Input is Appreciated.
>>The Color Code of the Wires May be Different than those I Use as a Reference in the Instruction File.
>>**PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed.
>>**Now. On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch (Clutch/Brake) Jumper from Same Color Wire (Example: White to White) First and then Check for Fire, Now Include the Black to Black Wires if No Fire. Check the Clutch/Brake and the Blade/PTO Safety Switches First. Then Check the Oil Guard Switch (if Applicable). Check the Seat Safety Last. Usually the Seat Safety is Not in the System for Starting the Engine. Just to Ensure Someone is in the Seat when Engaging the Transaxle and/or Blades. Use a Paper Clip or a Short Wire to Make a Jumper.**
>>Use a Multimeter and Check the Continuity of the Switch. The Meter should Show when the Contacts are Closed and Open. The Meter will Swing All the Way Over when the Switch Contacts are Closed and Swing Back to the Rest Point when the Switch Contacts are Open.
>>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Garden
Garden Logo
438 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
