MFC465cn-when I replace black cartridge it tells me that there is no cartridge
  • 10,865 Answers
Remove the black cartridge again then replace it with a firmer push to seat it. If that doesnt solve the problem unplug the printer and repeat those steps. good luck.
Posted on Jan 25, 2009
Mfc465cn-cant print test page,error PRINTER BUSY
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: How do print network configuration page Brother In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Jan 22, 2014 | Brother Any 8 Inks Mfc-465cn Mfc465cn...
Brother printer mfc465cn magenta color not printing
The print head may be plugged. there is a procedure to clean it in the printer maintemance menu
Dec 30, 2013 | Brother Any 8 Inks Mfc-465cn Mfc465cn...
Mfc465cn reads unable to clean 4f
Go To Below official Brother Printer Video For Your problem, Still having Problem Then follow Us For
Nov 03, 2013 | Brother Any 4 Inks Mfc-465cn Mfc465cn...
I have replaced black ink but printer keeps telling me to replace black ink cartridge
If the it's a remanufactured cartridge (not genuine), the printer will not detect the ink in the cartridge.
If it's genuine, you might want to give Lexmark's technical support a call to have the cartridge replaced.
May 05, 2012 | Lexmark X4650 InkJet Printer
Changed black cartridge now small black dots on all pages, even on test pages. bad cartridge?
Run the "Disable Cartridge Check" diagnostic
It will allow you to put the black cartridge in a different slot i.e. yellow. If the black cartridge in the yellow slot still puts black dots on the page...it is bad.
Can you put the original old black back in the printer. That will tell you right away if the replacement is bad.
Jan 20, 2011 | HP LaserJet 3600n Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
I replaced my black cartridge on my injet 2230 but it keeps telling me that i need to replace black printhead. I've tried two so i know it isn't a problem with the cartridge
The cartridge does not have a printhead included as part of it.
The printhead is a separate thing normally located behind the cartridges.
You need to replace the printhead, not the cartridge.
Jul 13, 2009 | HP Inkjet 1200dn Printer
MFC-240c ink erros. says i'm low/out after replacing
Your printer detects ink levels with an optical sensor that shines at the clear plastic in the center of the bottom of the cartridge. Once this area is no longer dark it will tell you to replace the ink. Since you installed full cartridges it could be that the sensor is cracking up. Another possibility is that you could have air in the ink lines that run between your cartridges and the print head. When this happens the printer cannot print the color that has air in the lines. You should be able to look in your printer to see the ink lines and see if there is air in the black one.
May 31, 2008 | Brother MFC 240C All-In-One InkJet Printer
Epson CX5400
Nothing wrong with the printer. The rubbish cartridge you bought and replace it with one that works. Approx 30% of most compatible/refilled cartridges DO NOT WORK.
Not only that but they WILL block your print head nozzles eventually. Ever wonder why Epson do NOT make any flushing cartridges but almost every compatible "maker" does??
99% sure the cart is at fault. return it to where you bought it and get a swap.
Jan 04, 2008 | Epson Stylus 680 InkJet Color Printer
60 people viewed this question
jasbo
jasbo
