Question about JVC TH-M303 System
Audio switches off after time.
My home theater system has begun to turn the audio off after awhile. Sometimes a few minutes and sometimes an hour. The video continues fine. Does this on every DVD. You can hear a click when the audio dies. I suspect a component temperature failure. Any help on which component is the culpret would be greatly appreciated.
Thank you
Russ Had the same problem and eventually the sub won't power up at all. 120VAC Input voltage to unit is present but when power transformer is connected it drags it down to about a volt or so. No opens or shorts on the primary of the tranformer but I suspect it's faulty. They run about $80-$90 new but I have more checking to confirm it's pooched.
  • 2 more comments
  • Mike Bissonnette Jan 25, 2009
    Transformer is Ok after lifting it from the board and testing (must have been stand-by relay holding it out). Put it all back together and now working fine?? Just a thought...check if cooling fan is working when powered up (mine isn't). Not sure if t-stat controlled or should be on all the time. If unit is shutting down after a period of time it may be heat related. Leaving mine on for while to see if it kicks out. If it does, will then check to see if fan ok or not....more to come.
  • Mike Bissonnette Feb 03, 2009
    Well, unit has been operational since Jan 25th. I ended up removing the transformer connector and hard wiring direct to the pins. Likely heated the pin and solved a bad solder joint problem from the get go. It sits on the floor and has good clearance for venting. Still wondering if cooling fan should be always on or just when called for.
  • john130 Mar 17, 2009
    I have the same problem ie audio cuts after an hour or so. But I also have no output to two speakers-LH Surround and RH Front. I have substituted speakers and they seem fine.so the problem seems to be with the subwoofer.Has anybody any ideas?
    John on the Wirral
  • beausswanner Mar 23, 2009
    I'm a Fireman who wants to hook up amy Fire DP radio to his home stereo system . I want to be able to listen to my tuner/T.V. but when I get a call over my radio I want everything to go silent and the Fire D.P. radio to take priority
    Genius:
  • 1,175 Answers
HI....
I was wondering where you keep the unit... Is it vented OK?
Is there dust about?
And , like the jan 25th comment, it could be just a bad solder joint or loose electrical connection.
It's not the transformer cause the video keeps working.
I would check all the speaker wires to make SURE theyre all connected solid at BOTH ends.
I have a Harman Kardon AVR in the shop and the customer said it shuts right down after you tunr it on,,,,,,well it'll do that if the speakers arent ALL connected.
Posted on Jan 27, 2009
  • JVC Master
  • 5,309 Answers
You can get a spray designed for electrical servicing that will freeze a hot running component from electrical service suppliers.
Posted on Jan 26, 2009
Why does my Samsung HT-5400 receiver switch modes automatically?
We are having the same issue for the past few weeks. The system worked fine for a few months before hand. Were you able to get it resolved?
Sep 04, 2012 | Samsung Ht-e5400 5.1 3d Ready Blu-ray Home...
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
Sanyo DP32649 works fine for a few minute, then sound goes off. turning the TV off for a moment & then back on restores the sound. But sometimes this will happen ever few minutes for the length of the...
I have the exact same problem. It's a volume control issue. For me, when I turn my TV on and have it on low volume, it works fine (but sounds somewhat distorted). But once I turn the volume up to normal levels, the speakers crackle and then go out. I opened my tv and checked my speakers, and they were perfectly fine; not blown or anything. As well, the audio processor and circuitry didn't appear burned at all.
This used happened every few months for 30min or and hour at a time. Then, about 2 months ago, it happened again, and ever since then it still hasn't worked properly. The only way I got around this was by buying a cheap 2.1 speaker system, and connecting it to the audio output on the TV. Or you could buy a speaker bar or home theater system. I believe this issue has to do with problems with the circuitry in the audio amplifier, and there's not much you can do except add external speakers, or contact Sanyo if you still have an active warranty.
Depending on where you bought your TV (such as from walmart), its possible that the LCD panel was produced by Sanyo, but the electronics were done in China. Walmart does this with nearly every TV they sell.
Jan 30, 2010 | Sanyo DP32649 31.5 in. TV
55 inch toshiba led tv audio sometimes gets garbled. must turn set off and on to correct
I have a Samsung 55 inch plasma that has experienced intermitent garbled audio, sometimes very frequent (a couple of minutes between episodes) and long in duration (several minutes). Switching to another channel and back would correct the audio.
I ran the auto program channel function a couple of times and it eliminated the gabled audio problem, except for infrequent (once every hour or two) and very short (a second or two in duration) episodes of gabled audio.
I found a thread on a CNET forum on this subject and it seems that the garbled audio problem affects a number of Samsung flat panel models.
Jan 16, 2010 | Televison & Video
Feedback
Is your audio equiptment grounded and all levels at a decent level with no over gain
May 18, 2009 | Nu Mark Numark Dxm06 DJ Mixer With 12...
Power turns off
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 31, 2009 | Samsung HT-X50 System
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
Samsung HLR5067W
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
Nov 16, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Panasonic SC-HT900 Audio problems
http://www.datasheet.in/search.php
Sep 06, 2006 | Panasonic SC-HT900 System
JVC TH-M303 System Logo
114 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
