Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
My Miele dishwasher is not heating the water.
The element measured 30 ohms which I assume is normal for a 240v system. Does anybody have any ideas.
  • Robert James Jul 16, 2007
    If I had a wiring diagram that was what I would have looed at next. However I put it together again and ... it worked. So for now problem solved thank-you.
    Novelist:
  • 159 Answers
You would need to look at the wireing diagram and find out if there is any thermostats that I'm sure there are. You would need to find out if they are working properly.
Posted on Jul 13, 2007
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Miele Dishwashers
My miele dishwaher is not heating the water thus not wahsing the dishes properly
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 26, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
I have a Chef Classic dishwasher ( model B8913WW) which is no longer heating the water, I assume I need to replace the element but nobody in my area knows where to get parts for this make or model, any...
If you know how to use a multimeter you can get to the heater connections and check the resistance of the element. it chould be about 26 ohme. Also the over heat protector thermostat should measure zero ohms. Make sure all wires connected to the heater and thermostat are solid. There might be a broken wire in the door loom from the lom flexing or the controller may not be sending power to the heat circuit.These are the pissibilities. if you measure the wire coming to the heat circuit and no power comes then the controller is the problem. if the controller is electronic check thatb there arent any burn marks on the controller. If you fimd a poor soldered joimt on he controller you can solder it. good luck
Jul 31, 2010 | Dishwashers
What is the the test for the heat element
All you need to do is set your controls to heated dry cycle, and see if the interior heats up nice and warm. You can also check the element by touching it when it is not heated, and note how warm it is, and then when you run the heat cycle. Careful not to burn yourself.
Oct 15, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Dryer will not heat but will run.
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 10, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not putting out warm to hot air. What is the issue?
May 07, 2009 | Dryers
Dryer takes too long to dry clothers and yes I cleaned all the vents and there is no clog or stoppage in vents
May 06, 2009 | Estate TEDS740JQ Electric Dryer
My Dryer Will Not Warm Up Or Heat Up At All!!!
May 05, 2009 | Dryers
Dishwasher wont heat water
if you have 240v going through the element then you have a broken neutral somewhere.Check the wires in the door,the thermostats,or the timer/pcb.the elemwnt wont be faulty.
Feb 29, 2008 | Dishwashers
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
328 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
