Question about LG Asmc183vm Neo Plasma Filter
Lg neo plasma sleep mode flashing red & system will not switch on
The sleep mode light is flashing red and the system will not switch on. Sleep mode was not set, and has been cancelled several times, but still the system will not switch on. This problem has impacted 3 units at the same time
  • Mr Jonathan A Carroll Feb 11, 2013
    hi, did you resolve the prob? mine have just done the same.
SOURCE: lg trax will not sleep
no i didn't.
but you guys ****.
stop trying to sell me your service and fix my problem already.
I'm sure you can make money just off the advertising (word of mouth) alone.
thanks, but no thanks.
i'll figure it out by myself.
Posted on Mar 13, 2008
  • 334 Answers
SOURCE: need to find manual to download for LG 2.5 hp neo
You can find it her, you just need to have the full model number, probably located in the control panel http://www.lge.com/us/support/product/support-product.jsp
Posted on Jun 11, 2009
  • 541 Answers
SOURCE: PLASMA SCREEN GOING INTO SLEEP MODE
Is there a moving picture on these sets or are they still? Some sets will shut off at predetermined time if no activity is detected in the video. This is a protection so the screen does not get "burned" so to speak. Just a thought.
Posted on Oct 13, 2009
JULIANFIX
  • 975 Answers
SOURCE: Just wondering how to set the sleep time on LG
go to their site , you might be able to download the manual , heres the link:
http://www.lge.com/support/manual.jsp
Posted on Oct 24, 2009
Testimonial: "oh thats GREAT -thank u much. I was having trouble finding the site to download the manual. This is mucho, mucho appreciated"
  • 8457 Answers
SOURCE: When I turn it on (with remote) it goes from
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com for a refurbish power supply board for the replacement.
Posted on Mar 02, 2010
How do I stop the anti-theft device red blinking light? Car is off and locked and from the window can see the red light blinking.
the red light drain 0.001amp. from you battery.need 1000 hour to drain 1 amp. test the battery if is any good. do drain test on the car.rust and short will drain battery overnight.after market equipment,light in the trunk or glove box, under hood light etc. disconnect the battery and install amp meter. do the drain test. your computers uses 0.2-0.4amp when sleep.anything over 0.5-.6 amp is bad. after you connect the amp meter give 1min. to turn all systems to sleep mode.Is normal the first minute to be high drain.
ones you know something is wrong disconnect the fuses one at the time and note if any changes. if the fuse you disconnect turn the amps low note what system is connected to the fuse and you will know were is the problem
Oct 24, 2014 | 2003 Oldsmobile Alero
Flashing power button
If the power button is flashing or blinking, that means the system has entered sleep mode, low power state. I would suggest not meddling anything related to power, sleep mode was designed for reducing power consumption if the machine was not in use for a set amount of time. It also helps you reduce your electric bill.
If you want to use the machine if it is in sleep mode, just simply press the power button on the computer or by pressing the keyboard or mouse to get it out of sleep. Think of sleep mode as a 2 hour power nap.
Jan 19, 2014 | HP Pavilion Desktop a6300f Intel Pentium...
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
What the blue flashing light at the top for
The flashing light indicates that you are in "sleep mode" which conserves battery life. To switch it off go to Settings->Phone->Display and set Sleep Mode to "off".
Feb 09, 2011 | Nokia N73 Cellular Phone
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
I have a neo plasma LG air conditioner, i am having problems switching on to cooling, sometimes it works, other times it is just circulating the air, making the room hot, it is 4 yrs old.
Possible problem with the thermostat which might be sensing the wrong temperature and so is not switching ON the compressor. So if the AC works once it is ON then the gas and compressor seems good. So you must check the thermostat and control board. Set the AC to a lowest temp and try.
Jan 24, 2011 | LG Heating & Cooling
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
Red light flashing constantly on dc16 when on charge, used to just stay permantly red without flashing until it went green when charged up.
I had a similar problem when I bought an after market 2Ah battery. Would stay solid red for a few seconds then flash red. I believe my problem was that the battery had gone into "sleep mode" I.e. it was discharged to the point that it "sleeps" in order to protect itself. So......I simply attached a domestic DC multi adapter to the terminals on the battery that are marked + and - (the 2 outside terminals on a DC16 Dyson battery). Switched on the DC adapter for around 10mins and this was enough to "wake" the battery. It now charges as normal attached to the DC16 in the Dyson charge mount.
For a pretty in depth article on lithium battery sleep have a look at this:
http://batteryuniversity.com/learn/article/low_voltage_cut_off
Oct 29, 2010 | Dyson DC16 Root 6 Bagless Handheld...
The operation and timer lights on my Fujitsu split system are flashing on and off several times when the unit is switched off I noticed this after the system had stopped blowing air & I knew the room...
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Jul 11, 2010 | Fujitsu 24C1 Air Conditioner
LG Asmc183vm Neo Plasma Filter Logo
242 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
