Question about Radio Communications
How do I turn on the blue blinking light on on my blue parrot headset?
6I can't get the parrot to pair with my new iphone
turn on bluretooth then delete all pairings then turn on headphones and use phone to search for new devices
May 30, 2015 | Parrot Blue B250xt Bluetooth Wireless...
My blue parrot headset doesnt turn on
I'm not sure of this headset. But if you just unpackaged it I would try charging it for a good hour. Then try it.
Jan 04, 2013 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Trying to pair b250 xt with samsung rugby2 lots manual
Make sure you device is in visible mode first. In power off condition of headset, press on button for 30 seconds. When blue lights starts blinking fast then search on device and add it.
Custom Car Grilles
Aug 01, 2012 | Parrot Blue B250xt Bluetooth Wireless...
Wont take a charge on my blue parrot headset
charger problem - just verify with your electrician
Apr 15, 2012 | Parrot Blue Wireless Headset System...
Blue parrot lights blue and red keep flashing and there aren't any beeping noises
If your headset is 6 or more months old, it could be the rechargeable battery is due for replacement. The power supply or battery is the one thing that can cause all sorts of odd symptoms. I read your post and put a known bad battery into one of my 3 Blueparrott B250-xt headsets and did just as you described. If you would like to order a new battery for this headset, email me at ebhammonds@gmail.com. They are $20 and shipping is free.
Jan 02, 2012 | Radio Communications
Blue parrot b250xt when making a call cant hear it ring on parrot . When reciving a call you have to divert to hands free.
Seems like you have an issue that is very common. I had the same issue and phoned tech support (1 800 742 8588). The solution is to reset the headset. It is not printed in the manual 1 switch phone on and pair with headset. 2 when paired (blue light flashing) put the charger on the headset for exactly 10 seconds. 3 remove the charger. 4 the lights should be starting to alternating between red and blue. this means it is resetting. 5 as soon as the light quits to alternate, the headset is reset, and the problem should be solved.
This also fixes the Windows 6.1 audio problem.
Jun 20, 2010 | Parrot CAR PAICK3300 GPS Receiver
How to pair my blue parrot b250 with my phone lost my notes on how to pair
1. Turn headset off (panel 5).
2. Hold down the headset’s MFB until the red and blue lights
flash and you hear 2 rising tones, followed by 4 more tones.
Important: Wait for all tones and for both lights to flash. This
may take up to 15 sec. Release the MFB.
3. Follow the manufacturer’s instructions for putting your
cellular phone into Bluetooth discovery mode.
4. Wait 5-15 sec. while the devices discover each other.
When the phone discovers the headset, select “Pair” and
enter a passcode of 0000 when instructed. When pairing
is complete the headset’s blue light will stop flashing and
the phone will prompt you to ‘connect’ to the headset.
Enter “Yes” on the phone to connect to the headset. When
connected, the blue light will flash indicating that the
headset is in standby mode ready to receive a call.
USER GUIDE
Jan 03, 2010 | VXI Corporation Blueparrott B250-XT...
Wont audio to headset
The problem with the Blue Parrot headset not getting audio from the phone is a very frustrating one and it took several hours to diagnose the problem. (Especially the Samsung/ Windows side, in my case)
I have a Samsung I760 phone using Windows Mobile 6.1. After pairing, the headset is visible in the PHONE window, as it should. But upon dialling, the audio transfers from headset to phone.
While in a call, you can tap on the menu button and it should bring you to a menu that would allow you to transfer the audio from headset to phone and vice versa. But this action malfunctions in the Blue Parrot headset only. The Blue Eagle headset works fine.
MY SUGGESTIONS:
1) Chuck the hideously expensive blue parrot headset in the trashcan and buy yourself a blue eagle, available at truck stops everywhere
2) Pester the Blue parrot support staff for a replacement, or a solution at 1800 742 8588.
Make sure you understand the manual and especially point 13 dealing with the transfer of audio before you call them.
Other than this, the headset actually works fine.
adampotgieter@yahoo.com
Dec 15, 2009 | VXI Corporation Blueparrott B250-XT...
Nokia 6500 will not pair with Parrot ck3100
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Radio Communications Logo
59 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
