Question about Dishwashers
The normal wash cycle light is blinking on my GE gld4408rooww dishwasher. What does this mean??
2 Suggested Answers
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
My GE dishwasher will not change cycles when pressing the normal wash cycle button. The lights are all on, but I cannot change the cycle from light wash to normal wash. Any ideas? Can it be reset?
Most likely the keypad will have to be replaced. If the lights change, but the cycle stays on light, it's in the control module or the switch.
Have you tried cutting the power to the unit and re-powering? If it's connected to an always on circuit, shut off the fuse that controls it and turn it back on in a minute.
Jul 11, 2015 | GE Dishwashers
Kenmore Ultra wash mod.# 665-77963K703. normal wash light flashing. How do I reset.
How many times does it blink before pausing and repeating? 7 times? (That's a common problem - means "water not heating" error.) In some dishwashers, instead of pressing Heated Dry, Normal Wash, Heated Dry, Normal wash, you press the 3 left-most keys in the following order: 1, 2, 3, 1, 2, 3, 1, 2, 3. That will start the diagnostic cycle and clear the error, but if you don't find and fix the cause, the problem will come back the next time you run the DW. But before I try to explain how to fix the root cause, I would need to know how many times the light is blinking.
Jan 09, 2015 | Kenmore Dishwashers
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
Dishwasher lights up when Normal Wash is pushed, also heat dry - but when start is pushed all three lights (Normal wash, heat dry and washing) blink then go out and nothing happens. This occurred after a 2...
What is the make and model so we can better assist you? In the mean time shut power off to the unit briefly, then turn it back on and try a normal cycle. Will be watching for a make and model here.
Jan 20, 2010 | Dishwashers
I have a GE QuietPower3 dishwasher... the normal wash, heated dry, hot wash and hot start buttons are all flashing... can you tell me what is going on please?
try this, I was researching and found that this solution worked. While all the lights are blinking, close the dishwasher door and let the machine run through the cycles. This actually happens pretty fast. Then it will stop and quiet down and all the blinking lights will shut off. Then just press the buttons you want and hit start and the machine will start. The time it takes for the blinking light to shut off is about 1 to 2 minutes. It worked for me.
Aug 09, 2009 | GE Dishwashers
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
