SB-PC600 How to open the speaker
I have just bought a technics sc-dv290 hi-fi off of my cousin and found out the mid range and the tweeters have blown does anyone know where i could get replacent tweeters and mid-range speakers for it if...
As you probably know, these are the individual model numbers:
SC-DV290 the base unit
SB-DV290 speaker set
Front SB-DV290
Center SB-PC95
Surround SB-PS95
I'd scour Google or eBay for any or all of those models. Orphan speakers appear periodically.
Feb 10, 2011 | Technics SC-DV290 System
Looking for a replacement speaker for my Technics SB-LX7 floor standing 3-way speakers the top speaker on one of them is broken. Model # Technics EAS65PH313A6
OK. I suggest typing the model in on EBay and getting the cheapest one there is.
-K.R.
"I know what I know because I know what to do!"
Feb 07, 2010 | Technics SB-LX70K Speaker
What's the best sound card?
Sound Blaster is certainly a good name when it comes to sound cards, they've been around forever. If you're looking for quality audio and full use of your 5.1 speakers, SB live 5.1 will do the trick.
May 09, 2009 | Creative Labs Inspire T5400 Computer...
Speaker enclosures for SB-DV290
Yes technics is panasonic so call this number and tell them you are aking about the technics separates system. the number is for UK 08705 357357
Sep 30, 2008 | Technics SCEH790 CD Shelf System
NO DISC message
Open up the unit and clean the lens using a cotton swab and alcohol. If that does not resolve the problem, try a music CD and report the results here. I suspect that the optics have begun to fail. If that is the case, the music CD will play but a DVD will not. The optics assembly is available (part # RAF3023A-1) for about $60.
Dan
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
SB speakers error
I had the same problem but fixed it (no thanks to what I believe is an oversight by Pioneer!). The amp is a 7.1 system. What we are assuming is the rear surround (SB) is the default using a 5.1 setup. The amp uses the SR & SL as the default. So the solution is plug your rear speakers into the SR & SL & you should have your surround! (only took me 6 hours to figure this out, hope it saves you time!)
May 01, 2008 | Audio Players & Recorders
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
32 people viewed this question
 Grubhead
Grubhead
