Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Kithchen aid dishwasher model KUD101FLS spring on door broken. How do I access it?
  • 161 Answers
Take the bottom panel off so you can see the side of the dishwasher at the botom.
You will have to pull the dishwasher at least half way out to replace the door spring.
Depends on the water connection, drain, and electrical.
Sometimes this can be done by just removing the screws at the top which holds the dishwasher to the counter top, adjusting the front legs all the way up and pulling it out.
Water connection
If you have a flexable water line that is long enough, if not, the water will have to be shut off and the line disconnected.
The drain hose will have to be disconnected from under the sink if there is not enough slack to pull it out half way.
Same here, not enough slack then you have to disconnect.
Posted on Jan 25, 2009
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Jul 08, 2015 | KitchenAid Dishwashers
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
Broken door spring
This should not be hard to replace. It would have helped if you had provided the model number of the dishwasher.
You need to buy a replacement spring (best to get the pair) which looks like this item.
To replace you need to locate the second spring on the other side of the dishwasher and remove it. The front base plate needs to be removed first to get access to the spring anchor points. Use a screw driver or a nose plier to grab it and dislodge. Always make sure the door is shut to ensure least tension in the springs. Put the two new springs and close the base plate. MAINS POWER CHORD SHOULD BE TAKEN OUT FROM SOCKET WHEN WORKING ON THE DISHWASHER
Aug 07, 2014 | Baumatic Dishwashers
Manual for sears dishwasher item MOD#1440902214409000
I am not sure if you have got the correct model number.
Sears dishwashers are usually of the following makes - Kenmore, Maytag, Kithchen Aid, Whirlpool and the model number would be something like 665.xxxxxx
Can you please change the model number and post a comment.
Nov 20, 2010 | Dishwashers
Kitchen Aid Model KUDPQ1FLSS5 door counterbalance issue
One of the counter bakance springs OR the adjuster for it let go. I had a similar thing where the adjuster which was a thin metal "T" thing that screwed up into the spring as an adjuster folded and fell out of the spring.
Remove the bottom dress cover at the tope kick of the dishwasher. The springs are all accessable right there. The problem will be obvious. Just compare the two sides.
I had to beef up the "T" adjsuter in mine as it was too weak to continue holding in the spring.
One turns it into more or less coils of the spring to adjust the counterbalance.
Apr 21, 2010 | KitchenAid Dishwashers
The door to our Kitchen Aide dishwasher now drops down very quickly and it used to have some control when the door was opened.How difficult is it to repair?
Hi, it is likely a broken door spring, or both. Part number 9743986. You can access them by way of removing the screws in the toe panel below the main door panel. Be sure to shut off the power to the unit. With the toe panel removed you should be able to visually inspect for a broken spring, with the aid of a flashlight ot trouble-light. One hook will connect to the hinge while the other end hooks into the dishwasher frame towards the back. Hope that help's and thanks for visiting fixya. Please take a second and rate the solution provided for here today. Good luck. Macmarkus :)
Dec 25, 2009 | KitchenAid Dishwashers
Door drops hard and i have an error code 7 -
The door slamming open is a broken spring/springs. They are very easy to replace - remove the screws holding the dishwasher in... pull out slightly and replace with good ones on the sides.
Can you clear the error code by shutting off power to it?
(Mdl # helps)
Dec 01, 2009 | KitchenAid Dishwashers
I have a kenmore dishwasher that is 18 years old not sure of the model my wife tells me that the door seems heavier than before I am thinking a spring has let go if so how do you change the spring or fix...
Most likely the spring or springs that help the door up are broken. Usually, if you remove the lower front panel (usually 2 screws hold it on) you can access the springs. If they are broken, try your local appliance repair store for new ones. If they are that old, they may be rusted- be careful!
Dec 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
183 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
