Question about Refrigerators
Norcold fridge not cool enough
My norcold unit in my motor home is not cooling. The freezer gets to 30 to 35 degrees, But the refrigerator will not get below 52 degrees any ideas as to what the problem may be.
    Sniper:
  • 68 Answers
Yes very likely the cooling unit has stopped working. You need to do a bypass test by unplugging the thermistor on the inside of fridge. It will be attached to the fins. Give it 6 hours or so and check your temps. If they are the same the cooling unit is bad. If the temp goes down the thermistor or circuit board is bad. If you need more assistance feel free to call.
734 777 6432
Posted on Mar 23, 2009
I have a Norcold 611 and the freezer works fine, but the refridgerator wont get cold. Any answers?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Thetford Norcold RV Cooler/Freezer
BOTTOM NOT GETTING COLD
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 29, 2010 | Thetford Norcold DE0051 Refrigerator
Fridge is not cool enough 12 degrees C. Freezer is -3 degrees
The cooling air outlet is clogged or blocked. Cool air is not entering the fridge section as indicated by the low temperature in the freezer section. It shows that the compressor is working fine and the system is good. If your unit has a brushless DC fan motor that circulates air to the fridge section, it may not be working properly or not working at all. You have to replace it.
Nov 08, 2009 | Refrigerators
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
Norcold mod 1200 does not cool well in Az. during the summer time
air circulaton over the cooling unit on norcold is critical get out you owners manuakl look up baffels and make sure all are in tact and also no animals have made a home behind you refer you have done all you can do inside the problem lies on the outside of the refer where the cooling unit is
Jul 22, 2009 | Thetford Norcold DE0051 Refrigerator
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
387 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
