Question about Samsung Techsan LM1770A 17" Monitor
Samsung LM1770A 17
When it's turned off of display , the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? if it is monitor problem?
  • Anonymous Mar 13, 2008
    I tried to install this monitor to my Dell Pentium 4 Processor, 2.20 GHz w/400 MHz Computer but it has no picture!! The computer comes on but no picture! There are buttons on the front of it that say menu exit etc but nothing will work!!! It only had one connection from the back of the computer and then to the tower and no electric plug like my old Dell Monitor did so am wondering if it is not adaptable to my computer because of that???...Thank you for your help...."Mike" J. [email protected]
Solution found - ignore request.
Posted on Mar 14, 2008
  • Samsung Master
  • 12,061 Answers
Most probably the Power Supply, generally is in these things... perhaps the Electrolytic Capacitors have Dried out and gone bad and need to be replaced, often all I do is replace every large Electro on the Power Board, (Often with much higer Temperature and spec Caps) and that "Fixes" it..
Posted on Jul 15, 2007
SOURCE:
Hi, my monitor does not display anything but the lid light just keep blinking.
You should check your display cable from CPU to Monitor. If it just blinking then problem with you connection bitween CPU and Monitor So just check and keep enjoy.
Nov 11, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
On right side of my monitor 2 ,3 verticla lines or blinking.
That sounds more like a graphic card problem than a monitor one. try conecting your pc to a different monitor and see if the problem persist.
Good luck
Mar 03, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
The screen doesn't display
that means the computer is not getting signals from the cpu .. its because of cpu problem .. mainly dust inside hard disk connectors clena and refit memory and hard disk
Dec 02, 2007 | Samsung SyncMaster 793DF 17" CRT Monitor
LM1770A POWER ADAPTER 12V
Ok well the Power adapter is not really that special.. what you need is a Centre Pin POSITIVE 12volt at say 4 amp power supply unit. I would get it from Ebay.. perhaps even being able to get an exact one from Ebay.. Othewise try the Samsung site and purchace direct. Look here for an idea. http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=power+supply+for+LCD&_nd1=See-All-Categories
Jul 31, 2007 | Samsung Techsan LM1770A 17" Monitor
Samsung Techsan LM1770A 17" Monitor Logo
157 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
