Hi.my sound and devices properties doesn't work.i can't hear sound from my computer.and my microphone doesn't work.what can i do for it?
  • 98 Answers
Cheack you have the devide installed in Device manager
Posted on Jan 25, 2009
The microphone on my computer is not working. i can hear someone else on skyp but they cant hear me. and i can not record a video.
Is this a built in microphone on your laptop or a microphone on a external headset?
Make sure the Mic is not muted on your computer. In Windows, you can do this by going to the bottom right of your desktop in the toolbar and right clicking on the Sound icon. Select Recording Devices and make sure the Microphone item is not muted. Go into the properties of it and make sure the volume is not set to 0. Make sure it is not disabled as well.
Has the Mic ever worked before?
Comment back if you need and I will assist further.
Regards,
G33k
Jun 14, 2011 | Computers & Internet
Hi my mic is not working I've tried adjusting it to the control panel and sound device still it doesnt work, netbook is Hanspree. Thanks
If the microphone is not working but you are getting sound from the computer, check microphone in sound properties to see if it is muted or disabled. If it is not, just install an updated driver for your audio device and it should work.
Hope this helps.
Jun 06, 2011 | Hannspree HannsBook SN10E22BU3221 Netbook
How to detect microphone in laptop
I think it would be better if we check that the built-in microphone is working on your machine.
Internal microphone
The internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to better capture sound with the microphone.
-Adjust the notebook PC screen to place the microphone in the best direction for receiving sound.
-Speak directly into the microphone. Avoid speaking away from the microphone.
-When using the internal microphone, choose an environment without background noise.
Testing the record function on the notebook PC
1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
2. Click Record (the red dot) and speak into the microphone.
3. When you are finished recording, click Stop (the gray rectangle).
4. To play back the recording, click Play (the gray arrow pointing to the right).
If happens that the recording with the microphone have no sound we have check the settings.
Checking microphone settings
1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .
2. A Volume Control or Master Volume window opens.
3. Click Options , and then Properties .
4. Select Recording , and make sure Microphone is selected.
5. Click OK . The Volume Control window should change to a Recording Gain Control window.
6. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
7. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step
Ensuring the correct recording device is selected
1. Access sound properties:
-In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
-In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
2. Click the Audio tab.
3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
5. Click OK .
6. Close the Sound and Multimedia Properties window and test the recording.
Feel free to reply if happens the steps I've told you is not working. Hope it helps.
AnEspera
May 03, 2011 | HP Pavilion dv4000 Notebook
My computer will not see or hear sound from my microphone but i know it works
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 17, 2011 | Labtec Verse-514 Consumer Microphone
My microphone on my laptop does not work i checked everything test it nd cnt hear my voice..?
Click VOICE
That should be it.
Feb 16, 2011 | Toshiba (P000257700) Microphone
My built in mic is not working properly,when I call somebody hear me but I don't hear him!
If the other person can hear you then YOUR microphone is working fine.
The reason may be that his microphone is faulty (solution below)
Otherwise:
  1. Make sure the volume is turned up on your speakers (and if using external speakers they are plugged in / turned on) . To increase volume go to Control Panel, Sounds & Audio Devices and adjust the slider on "Device Volume" . Also click on "Loudspeaker Volume" and adjust the sliders there as necessary.
  2. Can you hear other sounds (like playing music or videos)? If yes then you need to adjust the audio settings for your calling program (skype or whatever). Launch the appropriate program Click on Tools and ' test audio properties' on the program tool-bar. Follow the instructions on the screen.
  3. Try plugging in headphones and see if you can hear better on them.
Click VOICE
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
Feb 09, 2011 | Toshiba (P000257700) Microphone
My microphone doesn't do it right.
Some of the Podcast mics are condenser mics and MUST be used with a preamp or DEVICE that supplies PHANTOM power to the mic.
You computer DOESN"T supply Phantom power.
Read up on Phantom power in Google to understand it.
Apr 03, 2009 | Behringer XM8500 Professional Microphone
External microphone not working
Check first if your sound card is working properly.
My Computer >> Right click...Properties >> hardware >> Device manager >> Sound
Then go to Start >> Control Panel >> Sound and Audio Devices .........hit ADVANCED
one dialog appears MASTER VOLUME >> Go to OPTIONS >> Then PROPERTIES..........
CHECK the MICROPHONE...........Hit OK.............
This will be fixing your problem (if your sound card is working well)
Oct 30, 2008 | Compaq Presario 700 470024-192 Notebook
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
