Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
FM Modulator Is there any way to boost the FM modulator?
You could also just buy an old tape adapter from radio shack for about $20. Hope you have a tape player in your auto. Heres what to look for: http://www.radioshack.com/product/index.jsp?productId=2361893&cp=&sr=1&origkw=tape+adapter&kw=tape+adapter&parentPage=search
Posted on Jul 27, 2007
  • 156 Answers
I haven't found any ways that work. A better option is to use this device http://www.xm-sirius-satellite-radio.com/SIRIUS_FM_Direct_Adapter_p/fmda25.htm to make a direct connection into your radio's antenna plug. This adapter allows your satellite radio to provide clear, static-free sound. It can be difficult to install, however, depending on how hard it is to get to the back of your vehicle's radio.
Posted on Jul 13, 2007
Pioneer cd player quit workin and i have static in radio could my fm modulator be bad and can that keep my cd player from working
Your modulator shouldn't effect the cd player. But it can cause static in your fm if you leave it on. Make sure the modulator is turned off before trying to use the regular fm. Also, if its a wired modulator, then check the antenna connections. If it's wireless than it should not effect anything. Depending on the radio, get a aux input on it. Wireless fm transmitters are the worst.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 25, 2012 | Car Audio & Video
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod . http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Jensen VM9510 Car DVD Player
How to get the dvd player to play threw my truck speakers?
if you dvd play came with a wireless fm modulator read the owner manual and set up the fm station to get it to work . if it does not have a built in fm modulator you need to buy one.
the pull out your radio and run power to the fm modulator and then connect the factory anntenna to one side of modulator and the other side goes back to your factory antenna location at radio . then set the fm station you set for the fm modulator run a set of rca cables from the fm modulator to the dvd flip screen and it should work . i would think your flip screen dvd play would have a built in fm modulator that is wireless .
caraudioquestion@gmail.com
Oct 28, 2010 | Insignia Mobile DVD Player with 9.5"...
Hello i put a fm station in my mp3 modulator but when a turn off the car it lose
Take the end side of your modulator in your buttocks & then it will catch all the stations.
Jan 11, 2010 | Virtual Reality Sound Labs MP3/WMA FM...
Got a new mp3 fm modulator, no frequency is detected
u should set the fm frequency on your modulator as same as ur car radio. example, if ur radio states 100.00, set ur modulator 100.00 also.
Oct 10, 2009 | Virtual Reality Sound Labs VRFM7 MP3 FM...
Ipod shuffle, Xm reciever, Fm modulator
Yes it Does. The Ipod will not work in this Application. The FM Modulator is Programmed to Accept only Certain Connections. Please Rate My Response! Thanks!
Jan 31, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
Fm modulator on pioneer inno
I have learned due to fc regulations the fm modulator only works with the car kit. Looking into a device called a fm buddy that tricks the radio into thinking it's in the car kit so one does not have to pay the extra money for the whole car kit. I use a converter in my vehicle so I can use the home kit in my vehicle.
May 12, 2008 | XM Radio (XMP6000)
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
446 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
