Question about Pioneer DEH-P6800MP CD Player
Clarion PI 9993T radio wiring color diagram - Pioneer DEH-P6800MP CD Player
Need the wiring diagram for a Clarion RDX755Dz stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html#ANCHOR9 This is the basic wire diagram for all Clarion stereo's Clarion uses the industry standard wiring colors.
Jun 29, 2011 | Clarion RDX655Dz
I am changing out a Clarion ARX7570z to NZ500. Have most of the bugs worked out but I need a wiring diagram for the ARX to figure out the which wires are which. HELP!
the wiring diagram is out dated for the cassett player ....
here is what i know
red is ignition swichted
yellow is contstant power
black is ground
blue power antenna
blue with white strip amp turn on
gray + f right speaker
gray/black strip - f right speaker
white is + L front speaker
white with black strip is - L front speaker
green is + L rear speaker
green with black strip - L rear speaker
purple is + r rear speaker
purple with black strip - r rear speaker
your orange with white strip is illumanation not used
100% of all aftermarket radios are color code this way if you have install diagram for new radio it will be the same as old clarion radio ..
but make sure u have a digital volt meter to check power on red and yellow wire and comming from the factory harness be for you connect new radio just to make sure it does have powers and check other wire for power also just so you dont blow up new radio ... you can blow up a radio by connecting a wrong wire faster than you can blink your eyes ..... if you need a wire diagram for you modle car email me with it a http://www.tintingbyfredjohnson.com and go to contact and send email
Dec 28, 2010 | Clarion ARX7570z
Color diagram for a clarion radio
If this is a factory radio - the year would be required.
However just before 2000 model year... and for a couple years after - the following wiring colors are prettymuch constant....
Constant 12V+ Red/White Switched 12V+ Red/Yellow Ground Black Illumination Green/Red Dimmer Red/Yellow Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Blue Left Front (-) Yellow Right Front (+) Green Right Front (-) Gray Rear Speakers 4" Roof Mount Left Rear (+) Orange Left Rear (-) White Right Rear (+) Orange/Blue Right Rear (-) Orange/White
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 07, 2010 | Clarion Car Audio & Video
Need to know the color codes to hook up the wires to my DB 335 Clarion CD player, or need the schematics.
While this diagram may not be specific to your CD player, it appears to cover multiple models of Clarion mobile products:
http://www.clarion.com/us/en/support/faq/SourceUnits/Diagram.html
Hope this helps!
Feb 24, 2010 | Clarion DB-335 CD Player
I remove My clarion rdx755dz from 89 lincoln,which was install by Best Buy 8 yrs ago. I would like to reinstall in a 2000 Blazer. but unable to find a color code diagram for the radio . The plate said...
did you go to best buy and ask them if they have the wiring harness to adapt it to a 2000 chevy blazer if not write clarion at clarions website and ask them for the color diagram or you could also call your local car audio installation store and ask them as long as you have the model number and stuff im sure there shouldnt be a problem with that
Dec 07, 2009 | Clarion RDX655Dz
Clarion db165, need a wiring diagram
i have a clarin db165, and i need a wiring diagram or color sheet.... please! i've looked a;; over the internet with no luck.
Mar 26, 2009 | Clarion (DB165) CD Player
Clarion radio wiring diagram
Usually the yellow is for ignition switched-red is permanent +...;)
Aug 03, 2008 | Clarion ARX6670Z Cassette Player
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Mar 18, 2008 | Clarion DB245 CD Player
Installation
i suggest getting a wire harnees kit from an auto supply shop{pep boys,autozone,)the wire are usually color coded.also try going to to clarions support site they probably have a diagram 4 u.if not get back to me and ill tell you how to test and discorer what wire is what.if you connect wrong wire you can burn out your radio
Jan 21, 2008 | Clarion DXZ945MP CD Player
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
May 28, 2007 | Clarion DXZ645MP CD Player
Pioneer DEH-P6800MP CD Player Logo
193 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
