Question about Motorsports
1999 Ford Taurus heater blows only cold air. How can I fix this
Even when the car is warmed up, it only blows cold air, making it almost impossible to defrost the windshield.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
It could be your heater core, that's all I can think of at the moment.
Posted on Nov 01, 2013
2002 Ford Taurus, Heater blows cold air?
What have you checked so far ?
Radiator full of coolant ? Heater hoses getting hot ?
Feb 23, 2015 | 2002 Ford Taurus
My 1999 ford taurus heater doesnt work. We recently had a problem with the reservoir boiling over and brown coolant. Had the thermostat replaced and replaced the radiator cap. Also flushed the radiator....
Sounds like the heater core may be blocked..First check the level make sure its full..Then let the vehicle get up to operating temperature..Feel the heater hoses going into the firewall..Both should be hot to touch..If one is hot and the other one is warm or not warm ,,then you have a blockage in the heater core..If its block ,,then i have cleaned them out by taking the heater hoses off,,and running a garden hose through the heater core..If that doesnt work then you have to remove the dash,,and replace the heater core..
Sep 24, 2011 | 1999 Ford Taurus
1999 ford taurus se 155thousand miles, 3.0 V6
sounds like your thermostat is stuck open, if its takes a very long time for the engine to warm up and you get nothing but cold air from your heat then thats the first place i would start.
May 21, 2010 | 1999 Ford Taurus
1999 Ford Taurus, no heat. Air comes thru all vents but blows cold air like the ac is on. Replaced thermostat twice, flushed heater core three times (just did it), still ice cold air. Both pipes going into...
ford you say
check that there is flow coming out your heater hoses
step 1 remove 1c heater hose
step 2 have a friend start car remember it is easy to install a heater flush valve and it makes the job easier
if there is flow then eithor you have a blockage or an air lock
if there is no flow there might be a valve in the heater lines to stop the flow of coolant to the car when ac is on i have seen theise in a few cars but they are rare if there is a valve than make sure it isnt frozen with rust and ir does work in a ford i would assume that it is a vacume valve
good luck and happy hunting
Dec 30, 2009 | 1999 Ford Taurus
Heater blows cold air have replaced the thermostat
sounds like the controller went bad use temp checker see what your temp is at inlet of heater core from hose
Sep 08, 2009 | 1999 Ford Taurus
Ford ka blows hot air even set at cold
sounds like heater control valve situated under scullle panel common fault on ka set heater fan switch half way between hot and cold with heater blowing then touch valve if pulsing or clicking noise it is faulty if doesnt solve problem faulty switch
Jun 07, 2009 | 1999 Ford Taurus
Ford ka heater blows hot air all the time
Taurus does not use a heater control valve. It runs coolant thru the heater core constantly. You may have a temp blend door actuator problem or a plugged up heater core is also very common. Feel the heater hoses, they should both be very hot, it one is much cooler; you can try to back flush the core.
Mar 26, 2009 | 1999 Ford Taurus
Heater
Have the cooling system flushed or remove the hoses from the firewall(when cool) and blow out heater core with compressed air-clogged heater core..
Jan 14, 2009 | 1999 Ford Taurus
Motorsports Logo
67 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
