Question about RCA TruFlat 27F520T 27" TV
Blue screen of death
When I first turn on the tv I'll get a blue screen and it'll turn its self off in approx. 2 min. then I'll turn it back on and the same thing. Takes about 5 to 10 min. to get the picture on sometimes less.
  • 1 more comment
  • hollandhicks Nov 24, 2007
    Same complaint
  • Grunt12 Feb 21, 2008
    Same Problem on a 27V414T. Had it stored for over a year but it was still in it's new and unopened box. When I finally put it in service it worked really great but but that only lasted 2 days before the problem occurred.
    On the morning of the third day I turned it on and had a blue screen showing with unblanked vertical retrace lines in it. It would stay that way for about a minute and then turn itself off. Audio was still working fine but video was not. Tried other input sources and had the same results. Thompson was no help whatsoever. An email to them resuled in a generic email back with a phone number to call which was an automated service front end with no choice that applied to my problem and if I hit a 'O' to try to get to a live operator it disconnected. I have not found a service manual on-line and have no idea what to do next... Any constructive feedback would be appreciated.
    thank you...[email protected]
  • melkenglo Mar 29, 2008
    I have the exact same problem. just started yesterday. all i get is a blue screen that displays: Cable Channel 3. Is this something that I can fix myself?
  • 147 Answers
What you Have Is a Main RCA Failure you Have a Cathode to Grid Short In your Picture Tube,The Tube shorts and Tells the Miainboard to shut Down...Good Luck
Posted on Jul 19, 2007
    Sergeant:
  • 291 Answers
One simple test is to unplug ( while the TV is OFF) the CRT & turn the TV on. You won't see or you SHOULD NOT see anything, but if the tv does not shut down, you found part of the problem. If the TV still shuts down, that is proberly not the problem. Depending on the circuit u have to continue unpluging things [ turn TV off 1st because there are a lot of circuits that don't like surges as u unplug them while they are ON !!] & see if the TV will shut down. If the TV does not shut down, check filter capacitors 1st, 2nd check resistors that have changed shape & or color.
Posted on May 27, 2008
    Problem Solver:
  • 11 Answers
On this model if no signal is present you normally will get a blue screen. This shutdown probably is the CRT, try adjusting the G2 slightly up or down. If the tube has changed value, resetting this will sometimes work.
Posted on Feb 06, 2008
SOURCE:
Samsung 56in big screen lights flashing-cuts off
theres defective caps in the power supply
Apr 25, 2010 | Samsung Televison & Video
Rainbow vertical lines on screen
THAT HAPPENS WHEN IT GETS TOO HOT, MAYBE YOU HAVE TOO MANY THINGS PLUGGED INTO THE SAME OUTLET
Apr 28, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Screen
Sounds like you LCD has gone bad... Its like a calculator LCD when you press down on the screen of it it get like a blob. My projector also has done this... Half of the screen is all blue
Sep 06, 2007 | Hitachi Performa CP-RS55 Multimedia...
RCA TruFlat  27F520T 27" TV Logo
147 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
